Which power supply do you reccomend?
fej180
Its been a long time since I built my last computer. I am still running a single core processor with 2 gbs of ram. I am currently in the process of buying pieces for my next build. So far I have the case, motherboard, processor, and video card. I already have the other pieces picked out, but haven't purchased them yet.
Anyway, I am not sure what power supply unit I should get. I don't know how much power I will need. I will list the specific parts I have, and I would greatly appreciate it if anyone could recommend me with a power supply that would be sufficient enough to put out enough power and also be reliable and last for a long time. Thanks
Case:
COOLER MASTER RC-692-KKN2 CM690 II Advanced Black Steel ATX Mid Tower Computer Case
Motherboard:
GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
Processor:
AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo Socket AM3 125W Six-Core Desktop Processor HDE00ZFBGRBOX
Video Card:
SPARKLE Calibre Series X460G GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
RAM x2:
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMZ8GX3M2A1866C9
Hard Drive x2:
Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Disc Drive:
HP BD Combo SATA Model BD240I-h01 LightScribe Support
I will be running Windows 7 Home Premium 64 bit. If you have a chance to suggest a power supply that would be great. Thanks
If you will be using it only for gaming then the above suggestions will be the ones you should with.
And the PSU daisymtc linked is an awesome PSU.
why 16GB of RAM?
I am not sure if I will need 16 or not. I am going to start with 8 and so if there is a need for 16. I am going to be doing alot of audio recording at high bit rates, running a lot of plug-ins and so forth, so their may be a need for 16.
you won't need 16GB RAM.
spend the extra $100 on video card to GTX 570
I suggest you got core i5 2500K + P67 mobo
PSU - XFX 650w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207007&cm_re=xfx_psu-_-17-207-007-_-Product
I already purchased the AMD processor and Gigabyte motherboard. Like I mentioned above, I will be running alot of audio plug-ins and recording multiple audio tracks and such, so I may need more RAM than you might think. I will also be gaming on it moderately, however I do most of my gaming on the PS3. Thanks for the suggestion on the PSU, I am looking into that one.
Thanks for your help, I think thats the one I will be going with.
Fej180
