I recently bought a used laptop. Gateway MT3705. CPU 1.60GHz, RAM 958MB,32 Bit. Will the speed improve with upgrading to 1 GHz of RAM? My desktop with similar specs is much faster.
That laptop has a max memory of 2gb, which you will still have issues with running Vista. You should have at least 3 gb to run it effectively.
Whaa? Not normally one to question a mod but that sounds a tad off. I believe you mean 1 gb will run but with some speed issues, 2 gb to run effectively.
Just added Crucial 1G stick. Computer is not recognizing extra ram. Still shows 958 mb of RAM as before. What now? Had two 512 sticks before. Left one , replaced one.
I don't think you can add just one Meg stick, you need to remove the one stick and ass a two Meg stick.![]()
