mihir
So I finally decided to overclock even thought I have a hot-chip but I just decided to F@#K that.
NOTE:This is the First Time I overclocked a CPU.
So I used two guides
First this one - http://www.bit-tech.net/hardware/cpus/2008/11/06/overclocking-intel-core-i7-920/1
Which was a quick and dirty and a brainless overclock.
And another guide which I quite liked - http://www.overclock.net/intel-cpus/538439-guide-overclocking-core-i7-920-930-a.html
For all methods my turbomode,speed step and CiE and all spread spectrums wre turned off and LLC was turned On.
Using the first method.
My setting were
BCLK Frequency - 200(MHz)
DRAM Frequency - 1,600MHz
CPU PLL Voltage - 1.96V
QPI/DRAM Voltage - 1.35V
DRAM Voltage - 1.66V
Which gave me an unstable overclock of 4.0GHz+.I only had enough time to run Superpi mod and got the score of 10.28s for 1M.
Then since i encountered BSOD 0x124.
So I then I tried the other guide.
So here were my settings.
Multiplier - 21x(For all)
First Try.
BCLK - 143MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3V
QPI/Uncore - 1.3V
Got a stable overclock of 3.003GHz
Second Try
BCLK - 163MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3V
QPI/Uncore - 1.3V
Got a stable overclock of 3.423GHz
Third Try
BCLK - 183MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3V
QPI/Uncore - 1.3V
Unstable Overclock of 3.843GHz
Fourth Try
BCLK - 183MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3125V
QPI/Uncore - 1.3125V
Stable Overclock of 3.843GHz
Fifth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3125V
Failed.
Sixth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.325V
QPI/Uncore - 1.325V
Failed.
Seventh Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3375V
QPI/Uncore - 1.3375V
Failed.
Eightth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.35V
QPI/Uncore - 1.35V
Failed.
Ninth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.4V
QPI/Uncore - 1.4V
Failed.
Tenth Try
BCLK - 193MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.35V
QPI/Uncore - 1.35V
Failed.
Eleventg Try
BCLK - 193MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.4V
QPI/Uncore - 1.4V
Failed.
So my final config is
Fourth Try
BCLK - 183MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3125V
From the above I have deduced that I have the worst Core i7 920 chip ever manufactured.
The Chip is hot the worst overclocker.
And I also have an ambient temperature of 37C
So Now it idles at 49C and Max outs on 79C.
So please comment.
Also any suggestions or criticism welcome and desired.
My setting were
First Try.
BCLK - 143MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3V
QPI/Uncore - 1.3V
Second Try
BCLK - 163MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3V
QPI/Uncore - 1.3V
Third Try
BCLK - 183MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3V
QPI/Uncore - 1.3V
Fourth Try
BCLK - 183MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3125V
Fifth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3125V
Failed.
Sixth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.325V
QPI/Uncore - 1.325V
Failed.
Seventh Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3375V
Failed.
Eightth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.35V
QPI/Uncore - 1.35V
Failed.
Ninth Try
BCLK - 203MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.4V
QPI/Uncore - 1.4V
Failed.
Tenth Try
BCLK - 193MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.35V
QPI/Uncore - 1.35V
Failed.
Eleventg Try
BCLK - 193MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.4V
QPI/Uncore - 1.4V
Failed.
Fourth Try
BCLK - 183MHz
Memory - 8x BCLK
QPI - 18x BCLK
Uncore - 2x BCLK
CPU PLL - 1.88V
VCORE - 1.3125V
So please comment.
