Restore Windows Xp to factory
HalfaMaster
Hello all :)
I have a small problem :/ I have a EEE pc and i wanted to set the windows XP back to factory (like after i instaled the windows), I know there is a programm for that but i forgot the name. I also know i can use a USB pen to install the Windows, but i lost the Windows Cd... therefor i wanted to do that. I also know I can "go back in time" to a special point, but i tryed and dint went that far..
Can someone give me a hand?
Hello all :)
Did the EEEPC come with XP installed? I'm not sure because of this statement "like after i instaled the windows". If the EEEPC came from the factory with XP installed then I would check the ASUS website for instructions on how to do a factory reset for the model you have. If you installed XP after you bought it then the only way you are going to be able to restore it is by using the Winddows CD.
You will have to find out the key number for your windows and write it down, then borrow a windows version copy just like you have and reinstall and use your key.
There are free software programs you can download to retreave your windows key from your computer. Also the key may be on a sticker on your computer.
