Auxilary overheating
Epics
No matter what I do, my Auxilary seems to be overheating. (Sapphire Radeon 6970)
I have the following fans...
-Back fan 80mm
-Side panel fan 180mm
-Front fan x2 80mm
-PSU fan
-CPU fan/heatsink (Custom coolermaster)
I have no idea how to solve this. I don't want to use water cooling as it's a pain in the ass to buy all the thermal compound to replace every month.
Temperatures in general... I know my CPU is quite high, the thermal compound is very worn. I'll be replacing it soon.
The thing is I don't know what good temperatures are. This is hard to read for me.
Those temperatures are fine. Speedfan is showing a high temp for auxiliary because there's nothing plugged into it, so it reports a false number. HWMonitor doesn't show it because there's nothing plugged into it.
If you run hwmonitor in the background while you run games you can see what the temperatures get when doing something intensive. Generally you don't want to see any over 70c on the CPU and 80c on the GPU.
