RoRoYoBoat123
BTW thanks for comming and giving me your opinion
i was really hoping someone would
It will be about a week before I actually make my order and about a week till it comes in. By about mid may it should be ready, and as you can see, the theme is quite clearly blue haha
No problem, bro. I love helpin people. Its what its all about.BTW thanks for comming and giving me your opinioni was really hoping someone would
i have been saving for quite awhile for thisthe only thing i dislike about alienware computers is that you spend a shit ton in labor when you could easily build it yourself
Perfect example here, you could get three or four:
http://www.dell.com/us/p/alienware-m11x-r3/pd.aspx?ref=M11x
Did not even notice that dell made alienware.
Exactly the point. 1000 bucks for something that wont run in a couple of weeks.Its so bad though!
Nice, dude.Ya so alienware sucks i knew this when i looked at one for my first time, man i cant wait to build this comp, ill post pics here too,maybe with a building guide
Nice, dude.
I personally, on a scale of 1-5, 5 being the best, say that your computer is a 5. Easily.
Windows 7 should be no problem, but Vista is almost everyone's preference anymore, due to the fact that it's easier to use, i presume. Everything else is above and beyond of what i have seen, yes.
Motherboard:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131667
CPU:http://www.newegg.com/Product/Product.aspx?Item=N82E16819103913
Video Card(s): (3x, 2 bridged, 1 for physical)http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575
Memory:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231452
Harddrive:http://www.newegg.com/Product/Product.aspx?Item=N82E16820226153
Case:http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100
Power Supply:http://www.newegg.com/Product/Product.aspx?Item=N82E16817182239
CPU Heatsink + Fan: http://www.newegg.com/Product/Product.aspx?Item=N82E16835118074
OS:http://www.newegg.com/Product/Product.aspx?Item=N82E16832116997
Extra Fans: (2x) http://www.newegg.com/Product/Product.aspx?Item=N82E16835209011
Anti Virus: http://www.newegg.com/Product/Product.aspx?Item=N82E16832355022
Who prefers Vista?? I haven't heard of anyone enjoying vista.
Sweet rig I find the large SSD to be a bit much however. I don't see why you want your rig to be so bright I had led fans at first and got annoyed of the color it made on my walls while sleeping. Windows 7 pro is good to the only difference between the 2 is language support and bitlocker.
Dude! For gaming LGA1155 is a must, performance is far superior to anything AMD have at the moment. Asus Sabertooth 1155 + i5-2500K would be a better choice.
Yeah, as above Vertex 3 for SSD
