Green Xenon
Hi:
I'm thinking of a computer that does not need a central processing unit. Instead it uses multiple asynchronous peripheral processing units. Does such a PC exist? Can Windows run on it?
I am thinking that this hypothetical PC would have a 1-bit, 1 Hz, asynchronous processing unit for each bit of information that is being "processed". In addition, each of those bits would have their own 1-bit solid-state RAM.
If there are x number of asynchronous peripheral processing units operating at 1 Hz, then is it possible to obtain an effective frequency of x Hz by using all their 1 Hz signals? This is what I'm attempting to accomplish.
Also, if x number of bits have their own cache, wouldn't the ultimate result be a cache of x bits?
In this hypothetical PC, each processing unit is fixed to 1 bit per cycle. Brainiac processors rely on more bits-per-cycle to obtain a higher effective processing speed. Speed-demon processors rely on a higher processor frequency to obtain a higher effective processing speed. It is important to understand that more Hz doesn't necessarily equate to faster processing.
Thanks,
Green Xenon
Thanks,
Green Xenon
