News. ASUS said that the mobo is condemed. So i have been given a refund. So now i have to find another mobo. So would you reccomend ASUS or Gigabyte? (I am not too keen on ASUS now)
Which apparently translates to "Copy your ROM files to the flash disk, and then plug into the USB port, then boot and hold down the Ctrl + Home (or Ctrl + B or Ctrl + ES C, I do not know the model number of your motherboard, so I can not give you more recommendations.) wait 20 seconds or about some of the time, there will be RECO VERY interface, then BIOS has begun to recover. There, ROM to change the name, such as ATI to change ATIBOOT.ROM, you can try google.com for more information."将你的ROM文件拷贝到 flash disk,然后插到USB接口,然后开机,并按住Ctrl+Home(或者Ctrl+B或者Ctrl+ESC,我不知道你主板的型号,所以无法给你更多的建议。)大约等待20秒或更久一些的时间,就会出现RECOVERY界面,此时BIOS已开始恢复。还有,ROM要改名字,比如ATI要改成ATIBOOT.ROM,你可以尝试google.com获取更多资料。
