GirlyD
Try this,
it should work if it doesn't report back. :good:
http://download2.msi.com/files/downloads/dvr_exe/Realtek_AC97_MB.zip
SO i downloaded it and now i dont know what to do, it just shows me two folders . . . .
Try this,
Right click the downloaded file and click on extract,then go to the extracted folder and run the setup file there and follow the instructions.![]()
Extracting .zip Files in Windows:
Save the downloaded .zip file to the hard drive.
Right click on the file and select "extract all". This will open the extraction wizard.
Click "next" and then select the location to extract the files to.
Choose the option to "Make a new folder".
Click "ok."
Click "next" to begin the extraction process.
Make sure that the "Show Extracted Files" option is checked.
Click "Finish" when complete.
Once the package is downloaded
Then open the folder you will see a list of files/folders and double click the setup file and then follow the instructions and then reboot your computer.
How are you getting 2 folders.When I extracted it I just got One folder and in it the list of files.
Omg i fixed it !! lol!! after doing all that i fixed it , thanx Mihir![]()
now get her phone number![]()
Haha you won't believe how close I was to making the same joke:good:
Sigged![]()
