danthrax
A 128gb SSD...........................................
you have no idea how sad I am....but at least grats to you
What the hell are you sad for??
Aww c'mon, no need to be sad!I want one!
Thanks for the info Benny - I checked out the site. I had read a bit about dye stains, but I could not find anywhere locally to go and check them out in person. Calling a local millwork company is a fantastic idea. I have, unfortunately, already stained a few of the actual pieces, so this is what I will be sticking with for the entirety of the project, but I will certainly check out the Mohawk products in the future.Mohawk furniture grade waterborn dystain. Being a dye, the color turns out uniform and not muttled. The natural colors in the wood, make the color variations in the finished piece. The porosity of the wood(soft spots make bloches)does not affect the consistent color acheived, without the "wash" coat.(wash is usually 1/2 sealer-1/2 solvent but I make it weaker beacuse if its too much it may not all sand back out enough). With dye, no wash needed.
Each color the raw wood has, takes on it's own stained color. Make sence?Has that deep(as in depth, not dark) look, yet clean and clear. Like 3D if you will. Has that slight glisten like it's wayyy down in the wood, when the light shines on it. I think this is what your looking for. You probably have some furniture that looks like that.
Very easy to use, just brush it on, and let it dry. There are other alcohol/solvent type wood dyes but those are for other specialty finishes and the waterborn is the way to go. I know you been working on this stain for a while, and working hard I see, but I think you'll be glad you looked into it, if you do. They have mohagany, but it doesnt have to be that brand. I'm suprised Randalls didn't show/have some. Perhaps they do!
http://www.mohawk-finishing.com/catalog_browse.asp?ictNbr=178 suggest dark read mohagany. color can be easily adjusted/lightened from there if wanted.
If interested, call a couple Architectural Millworlk companies in your area, that do the finishing themselves.
Seriously!What the hell are you sad for??
I wish!!Is the build finished yet?
Slowly, but surely! It's taken a while to get here, but I can finally see the light on the horizon lolLooks like it's all coming together nicely
I can't wait to see the finished product.
lol, thanks for the support emac227, sorry things have been a little slow lately!ahh i need more updates. i check everyday to see if you posted more pictures!
Drilled thru to the piece underneath?
Hehe, I see what you did thereComing together nicely, quite literally
lol, never thought I'd hear it either!omg that looks beautiful
That is something I didn't think I would end up saying...about a desk
Thanks!Looks great man!
It's maple-veneered plywood, with Old Masters Deep Red Mahogany Gel Stain (2 coats + gloss poly)i really like the shine and that the grain in the timber shows too. what kinda wood are you using?
Hehe, same here!I want one!
