Gaming laptop for less than 2000ish
For 2 grand you can get a better video card in an alienware, though I would probably go for an ASUS anyway.
ASUS brand? Do you have a recommended website.
I was digging the fact alienware laser draws your name into a metal plate so if someone steals it it always has your name on it. Plus I was planning on using it to travel and if I got home I'd use a docking station to play or just the laptop
newegg
bestbuy
I post bestbuy because it is a surprisingly good deal.
Bestbuy ASUS is decent. But the alienware's card is 3.0GB DDR3 NVIDIA® GeForce® GT 555M using NVIDIA Optimus™ technology
Software & Services
Genuine Windows® 7 Home Premium, 64bit, English
Intel® Core™ i7 2630QM 2.0GHz (2.9GHz w/Turbo Boost, 6MB Cache)
8GB Dual Channel DDR3 at 1600MHz
750GB 7200RPM SATA 3Gb/s
14.0" High Def (720p/1366x768) with WLED backlight
Intel® Wireless-N WiFi Link 1000 a/g/n 1x2
None
8x SuperMulti DVD±R/RW Slot Load Optical Drive
Internal High-Definition 5.1 Surround Sound Audio
My Software & Accessories
Nebula Red with Soft Touch Finish
Personalized Plate
Plasma Purple
Steam and Portal™ Factory Installed
Eve Online, Factory Installed
My Accessories
3 Year Advanced Plan
Microsoft® Office Home and Student 2010
Also Includes
Adobe Acrobat X Reader
None
Automatic Updates: Critical Updates Only
Alienware M14X 150W A/C Adapter
Hinge Up WLAN - RED
Was what I got on the alienware.
Yes That's true, but based off these benchmark scores, the gtx 460 benches higher than the gt 555. And the thing is only 1200. But bro, I have an alienware myself and it's pretty nice, so I won't recommend against it.
I don't think so. The gtx 460 is still pretty powerful. Though, you can go to the asus website and find out more
