But I don to want print the document, I want to convert it then email the doc.
To further clarify, "printing" to PDF will convert it to a PDF file saved on your local machine. After that you can email the file or do whatever else you'd like with it. The converter will appear as one of your installed printers. You print the document, but select the converter as your printer instead of your physical printer."Printing" it to PDF will convert it.
