Hi I just bought a laptop broken for $60 the only problem was that Windows would freeze when I log in and just keep loading so I figured it was just a windows problem or maybe a hard drive problem I don't really know the specs but it has a AMD Athlon x2 and a 160GB Sata Hard Drive.
It's a hp presario f700
So another deal was for me to take all the data and give it to my cousin so I plugged it into my computer and copied the data everything went smoothly. then I deleted it and and went on the disk manager thing and deleted it and made it blank that went smoothly then I downloaded Ubuntu it loaded and ran the installer then I think it said it had trouble copying the installer I think it said it may also be a hard drive problem.
ALso when ubuntu was loading I was getting errno=-16 severel time but after trying 5 times it would boot.
So I want to know if the hard drive truly is broken and i should buy a new one
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136692
would the above link work on all sata laptops
I don't want to buy it and figure out it doesn't work.
I also tried to install ubuntu directly from my computer to the laptop hard drive and it finished but when i pluged it in it gave me that same black screen with the dash flashing.
Thank you.
Thank you.
