wonderboy1953
banned
Maybe more to the point, how much do they cost and how much can they hold if I can get one at a store?
for a cheap one, in a bustbuy...will cost you about 120 for a 64 gig kingston ssd. honestly id look at newegg for better pricing on slightly larger drives. a 120 gig one will cost about 200 bucks
Compared to mechanical HDDs, SSDs cost quite a bit more per Gigabyte but compared to what HDDs cost a few years back they aren't all that expensive. For instance, in 1985 I paid $500 for a 20M HDD.
Compared to mechanical HDDs, SSDs cost quite a bit more per Gigabyte but compared to what HDDs cost a few years back they aren't all that expensive. For instance, in 1985 I paid $500 for a 20 megabyte Hard Disk Drive.
Definitely! For the longest time a new computer cost $2000. As things progressed you got more and more computing power for the same price but you still needed to spend $2000. Finally, prices started coming down, hovered at the $1500 mark then slowly crept down from there. I remember what a big deal it was when the price of a new, low-end computer broke the $1000 barrier.Wow! Computers used to be so expensive. The price has really come down on parts. With inflation calculated (I looked it up) you spent $1,045 on a 20 megabyte hard drive in today's U.S. dollars.
My last 320 gigabyte SAMSUNG Spinpoint hard drive cost me $50. That would be $24 back in 1985.
I think it all kind of depends upon the size. Because for me a 500GB SSD is not that expensive.
Don't know what you consider expensive or which SSD you have but here's a 460G SSD for $1,200: OCZ Colossus 2 Series OCZSSD3-2CLS460G 3.5" 460GB . That's pretty expensive when a WD Caviar Black 500G HDD can be had for around $60.I think it all kind of depends upon the size. Because for me a 500GB SSD is not that expensive.
AFAIK all SSDs are writable so you're asking the same question that started this thread.Are SSD writable disks much more expensive than HDD disks?
Yeah RAID0 8 of them and you will get better speeds and more storage, the downside is you wont get the seek times of a SSD.
Id love a SSD more once they hit $1 per GB, 120GB HDD for $120 (specially a Intel) would get me to buy one. While I like the load speeds they really don't do much other than that so spending $240+ on a 120GB+ drive is not worth it to me. Plus they are a new tech so who knows what possible problems could be in store for the users. I think 1-2 more shrinks and they should be able to give us a $1 per GB drive but that will be 1-2 years away. This also depends on if the US doesn't crash![]()
