Motherboard and PSU compatible?
yer ok well i have a HAF 932. i had posted my spec on another forum and bought it but when i built it the PSU has a 24-pin ATX Power connector and
8-pin ATX 12V Power connector, and the motherboard has a 24-pin EATX Power connector and 8-pin EATX 12V Power connector
so is there a way roound this?
Yes, it will work fine.
What do you mean how you plug it in? The XFX is ESP12V, so is the motherboard connectors. You just use the 24 pin motherboard power connector and the 8 pin CPU power connector.
