maggiemay48
why does my arrow keep freezing on my laptop.Its so annoying!!!!
Not really wrong section. Its in laptops so it qualifies. And arrow is on a keyboard. Not mouse.
When you say it freezes, does the key get stuck down? Or it acts like normal, just the computer keeps the arrow going?
hi yes it keeps sticking.Computers normal.Not really wrong section. Its in laptops so it qualifies. And arrow is on a keyboard. Not mouse.
What the heck guys?! He means the little key on the keyboard with an arrow doesn't he?
Maggiemay48, please clarify.
Do you mean the key on the keyboard? Which makes the cursor move when typing? Does the key stick in the keyboard or pop back out?
Or do you mean the cursor on screen moved by the mouse?
Hi no when you move your finger around on the laptop.The arrow sticks.Its not a mouse i am using its my finger Its the arrow on the screen.Normal it does this if the bateries are going on a mouse.But like i said i am not using a mouseWhat kind of mouse are you using? If it's a ball mouse, take it apart and clean the little rollers.
