Ok here's the build. All comments welcome:
Processor: Intel Core i7 2600K (http://www.newegg.com/Product/Produ...m1132X509988X7404189d35cc17b41272c9830f420bac)
Motherboard: Gigabyte LGA 1155 Intel Z68 (http://www.newegg.com/Product/Produ...m1132X509988Xb1ef39766977e1ede04417c678371f6d)
Memory: CORSAIR XMS 8GB (2 x 4GB) 240-Pin DDR3 2000MHz (http://www.newegg.com/Product/Product.aspx?Item=N82E16820145325)
HDD: Western Digital Caviar Black 2TB @ 7200rpm (http://www.newegg.com/Product/Produ...re=wd_caviar_black_2tb-_-22-136-792-_-Product)
SDD: Corsair Force 120GB SATA II Internal (http://www.newegg.com/Product/Product.aspx?Item=N82E16820233125&Tpk=corsair force 120gb)
GPU: 2x GeForce GTX 580 in SLI Configuration (http://www.newegg.com/Product/Product.aspx?Item=N82E16814130587&cm_re=gtx_580-_-14-130-587-_-Product)
Sound Card: ASUS Xonar DX 7.1 (http://www.newegg.com/Product/Produ...6&cm_re=asus_xonar_7.1-_-29-132-006-_-Product)
Power Supply: CORSAIR TX Series 950W (http://www.newegg.com/Product/Product.aspx?Item=N82E16817139013&Tpk=Corsair tx 950)
Optical Drive: Pioneer Black BRD-Drive (http://www.newegg.com/Product/Produ...66&cm_re=Pioneer_black-_-27-129-066-_-Product)
CPU Cooler: CORSAIR Hydro H70 (http://www.newegg.com/Product/Produ...13&cm_re=corsair_hydro-_-35-181-013-_-Product)
Case: COOLER MASTER HAF X (http://www.newegg.com/Product/Produ...re=cooler_master_haf_x-_-11-119-225-_-Product)
Thanks in advanced
Thanks in advanced
