marquita188
CAN SOMEBODY PLEASE HELP ME FIX THIS!!!
I can't get on the internet, even time i shut down the bsod shows up.
i can't ever use startup repair. because it goes right back to the bsod.
PC info:
emachines
vista home basic w sp1
amd athlon le-1620
nivida geforce 6150se ingrated
DVD-+rw super muilt-format dual layer
160gb hdd
2gb dd2 memory
STARTUP BSOD
"a problem has been detected and windows has been shut down to prevent damage to your computer.
if this is the first time you've seen this stop error screen, restart your computer. if this appears again, follow these steps:
check to be sure you have adequate disk space. if a driver is identified in the stop message. disable the driver or check with the manufacturer for diver updates. try changing video adapters.
check with your hardware vendor for any bios updates. disable bios memory options such as caching or shadowing. if you need to use safe mode to remove or disable components. restart your computer, press f8 to select advanced startup options, and then select safe mode.
technical information:
*** stop: 0x0000008E (0xC0000005, 0xB12C976F, 0xBC6BB924, 0x00000000)"
SHUTDOWN BSOD
PC info:
emachines
amd athlon le-1620
160gb hdd
2gb dd2 memory
STARTUP BSOD
SHUTDOWN BSOD
