Gaming Rig
Looks pretty good. You do realize that you're gonna have to overclock your RAM if you wanna use 1866. 1600 is the highest the stock goes.
Do you need to spend that much on a power supply? They are the most important part, but there are corsairs that do the job just as well for less money.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Just an opinion. But if you need it, go for it. Otherwise this build will rip through anything.
I was looking at that bottom one you linked, but it's not modular. Call me lazy, but I don't want to have to sort through the mess of cables xD
OCing isn't really a problem for me.
Thanks!
