Rate my computer please RATE 1-10
serickk
Had some help from mmo-champion putting this together, any tips??
1-10 RATE !ONLY PLEASE
IntelR CoreTM i5 CPU 650 @3.20 ghz 2.67ghz.
8.0GB Dual-Channel DDR3 @ 803MHz 9-9-9-24
MS Windows 7 Home Premium 64-bit.
NVIDIA GeForce GTX 560 Ti.
ASUSTeK Computer INC. P7P55D-E PRO LGA1156.
Get new generation Sandy Bridge, i5-2500[K] [If overclocking]. Also you'll need an LGA 1155 motherboard like the P8P67. DDR3 1600 is very cheap, I assume that's what you mean when you say 803MHz. Do you have a PSU, Case, HDD? What is the PC going to do? Good choice of GPU
5
Will work for your purpose. But it is not the best value for money.
You should go for Core i5 2500K + Z68 mobo
If you are happy then 10.
We cannot rate computer since everyone has a different budget and looking at the config of the computer I cannot think of a better one in the same budget. :D
It is a really good computer and will last long and if it slacks in the future you can upgrade to an i7 870 :D
I would give it a 6. You could've gotten a better video card for around the same price if you went AMD. It is a nice computer, though, and can probably handle anything you give it.
I put score 8 of 10
Even though SB i5 is better than i5 650, i5 650 is not bad at all. If you didn't already buy i5 650, then I would suggest that you buy something like i5 2400. But if you already bought then thats fine.
Also, GTX 560 Ti is very good GPU and should run latest games without problems.
What it is to me and what it is to you could be worlds apart.
If you like it, and it serves your needs than it is a 10
