AGP Graphics Card
psaila
Hi. I have a rather old computer and I'd like to buy a good but not very expensive AGP graphics card. I have in mind to play Sims 3 although I'm net yet sure the computer can handle it. It's running windows xp. Can you suggest a good graphics card please.
@ claptonman
The HD3850 is the fastest card supported by the AGP 8x bus. Any faster and you will see no improvement in performance.
@ OP
you dont necessarily need to upgrade to an i3. If you have a LGA775 Pentium4 or core2 series, then you could just upgrade the motherboard to one with a PCI express port (about 10 times the bandwith of AGP 8x.) and transfer all your other parts.
Well, this was a long time ago and my graphics card died so I just need a replacement one. More like I wasted the difference between a 4670 and a 3850.
