Good PSU?
All loooks good, but you might wanna check out the reviews on the 6950, they say the fan is quite loud, if that irritates you you might wanna select a different brand or pick up a new fan :P. But anyways, yes, and great PSU. :D Good luck.
@Casey
My friend has that GPU and hasn't had too many complaints, and the noise doesn't really bother me. I kind of like white noise.
@StrangleHold
Thanks for the ideas. I'll consider them. Those RAM cards, are mainly for Intel boards, any problems with that?
It will probably boot at 1333. With a Phenom II you can get it to run stable at 1600 pretty easy, just by manually setting the memory speed/voltage and timing in the bios. Which is fine. To get over 1600 you will need to start bumping up the CPUNB voltage. But Zambezi will support 1866.
Alright thanks, I was kind of wondering when I still had my Phenom II. But I also read a feedback comment on it that someone manually set it in the BIOS like you said.
