Vista ultimate 32bit:random blue screen & refuses to shutdown/restart
cracker2
For awhile it never had a blue screen popup.It did take a long time to restart,shutdown normaly though.Now when I try to restart,after 20-30mins the screen goes off.But laptop is still on.Ill double tap(not hold) the power button and it seems that it works like that.I don't get the"windows did not shutdown properly,and shows the safe mode,start windows normaly etc etc.
Starts up like it was restarted correctly.Thought it was kinda weird.
Here is the dump for the random crash that happens.No I have not installed new ram,hd,etc.
Dump File : Mini070811-01.dmp
Crash Time : 7/8/2011 12:25:56 PM
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 0x00000004
Parameter 2 : 0x0000001b
Parameter 3 : 0x00000000
Parameter 4 : 0x81eefdef
Caused By Driver : hal.dll
Caused By Address : hal.dll+4000
File Description : Hardware Abstraction Layer DLL
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.0.6002.18005 (lh_sp2rtm.090410-1830)
Processor : 32-bit
Crash Address : ntkrnlpa.exe+4dfd9
Stack Address 1 : ntkrnlpa.exe+b0def
Stack Address 2 : ntkrnlpa.exe+ab71d
Stack Address 3 : ntkrnlpa.exe+ab6b3
Computer Name :
Full Path : C:\Windows\Minidump\Mini070811-01.dmp
Processors Count : 2
Major Version : 15
Minor Version : 6002
Dump File Size : 145,176
hal.dll,Ntfs.sys,& ntkrnlpa.exe are hilighted in red under the lower file name list.
Do you have the vista install cd? Boot to it and select repair your computer. Usally this is caused by a driver issue, any new hardware recently? Try updating the drivers.
Said the volume was clean.Waited for the restart and got another blue screen.
First one in my OP was IRQL_NOT_LESS_OR_EQUAL.
***STOP: 0x0000000a (0x00000004,0x0000001b,0x00000000,0x81eefdef)
This one showed,DRIVER_POWER_STATE_FAILURE
***STOP: 0X0000009F (0X00000003,0X835221C8,0X842B6F08,0X8A9A7E00)
When I ran the blue screen view again.It onley shows the IRQL error.
Definately sounds like a corrupted or bad driver. Go to your pc manufacturers website to download the latest drivers if its a store bought pc or motherboard manufacturer if its a custom built pc.
Ok.No.Its all stock.I use a logitech cam and a 500gb external(rarely use it,never leave it pluged in when not not in use).The external has no sys files,just media(music etc.).I am a bit confused with drivers.Should I uninstall all & then reinstall them?Or do they delete or overwrite the current ones?
You can try just overwriting them and see what happens. But may have to uninstall them first.
drivers to update...
chipset
lan
vga
audio
wireless
The audio, bluetooth and card reader are the same download but one is for vista and the other one is for windows 7, the other have 2 different brands so depends what one your system uses
tried the chipset first and it says:One or more files that are required for installation are either missing or corrupted.
Setup will exit.
I will uninstall my chipset driver,try it again then see what happens.
to get rid of the two driver listing use the operating system drop down on the right hand side of the screen, select vista ultimate 32 and then it only shows the drivers you need
Just got the chipset,VGA,audio,& wifi done.I think I chose the wrong one for wifi.Still shows 2 realteks after i select my OS on the gaetway link.Wifi seems to work fine,but shows no signal(no bars) in the wifi ballon on the bottom right.
Here is some copys off my event viewer.
Error->Log Name:Application
Source:Microsoft-Windows-WMI
Date:7/10/2011 11:32:57 PM
Event ID:10
Description:
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Warning:->Log Name:System
Source:CmBatt
Date:7/10/2011 11:21:12 PM
Event ID:54
Description:
The description for Event ID 54 from source CmBatt cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
Edit:Heres what came up after clearing the log and restart.
Error 7/11/2011 12:18:49 AM DistributedCOM 10010 None
Error 7/11/2011 12:26:48 AM Service Control Manager Eventlog Provider 7043 None
Error 7/11/2011 12:32:05 AM Service Control Manager Eventlog Provider 7009 None
Error 7/11/2011 12:32:05 AM Service Control Manager Eventlog Provider 7000 None
The Parallel port driver service failed to start due to the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
Error 7/11/2011 12:32:03 AM WMI 10 None
Services,idk much.I disabled and set manual the obvious ones like winodws live ID sign in etc.Its windows OS services causing all this I think.Can someone tell me the ones I can disable and or just set to manual?I want the minimum to run vista.And want my wifi,audio,display,usb ports,touchpad & keyboard enabled.I don't care for the card reader,external vga port etc.
