claptonman
Hello all. Getting antsy waiting for the bulldozers coming out so I'm trying to perfect my build so far. I need help choosing a motherboard. I don't know a lot about motherboards, so here's what I'm looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131757
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128510
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131754
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130604
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
My specs will be...
8GB RAM 1866 (The reason I chose these MoBos because they can support them)
ATI 6950
Corsair Nova 32gb SSD (The one in my sig)
WD Black 500GB HDD
and some sort of CPU cooler.
I'm thinking of going with the best 8-core there is, but I'll wait for benchmarks. I will probably use the turbo-boost AMD is advertising with all the CPUs
I want a motherboard that works well with SSDs, can do the turbo boost easily, and have enough room to fit an aftermarket cooler on. I would also like to be able to hook up my USB 3.0 ports on the front of my case to work with the MoBo.
Any suggestions out of these or any other ones? Advantages over the cheaper ones compared to the more expensive ones? Thanks for any advice.
My specs will be...
ATI 6950
WD Black 500GB HDD
