Dual screening problem
elobire
Hi,
im currently trying to get my dual screen set up properly, using my HD TV. The problem im getting is that although i have adjusted the resolution to match the screen of the TV the text on TV is too small to easily read.
I tried changing the resolution, making it bigger works, but then it doesnt fit inside the screen.
does anyone know any solution to this?
Thanks.
Only thing you could do is make the font size larger. High screen resolutions produce small font sizes.
The screen is going to look awkward unless you set it to a native or supported resolution. depending on the size, I would try 1366x768 or 720p and see if that doesn't look better
No guys. His problem is with the native resolution of the TV, his text is small.
With high resolutions, font size is decreased. There's not much you can do unless you want to try and enable large font. That might work.
