My Gaming rig build (Comments please)
Tuxaia
This is for mmorpgs mostly and i don't feel like waiting for buldozer(Unless it already came out i never was following and i finally came back here after a few months.)
And i guess my budget is Not over 700
I want to know if this rig can play something like Rift on high settings and handle Guild wars 2 when it is released.
AMD Athlon II X4 645 Propus 3.1GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Desktop Processor ADX645WFGMBOX
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=1i0hjssvkuy3t
ASUS M4A88T-V EVO/USB3 AM3 AMD 880G HDMI USB 3.0 ATX AMD Motherboard(Open Box)
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=183jpp5c7wyev
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=1bqjte8edgcaj
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=1v54bo2srffbu
Seagate Barracuda 7200.11 ST31500341AS 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=1lbm38sdbd4a8
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 1.5MB Cache SATA CD/DVD Burner - OEM
http://www.newegg.com/Product/Produ...-na&AID=10521304&PID=4169961&SID=7ivrbupip8my
CORSAIR Builder Series CX600 (CMPSU-600CX) 600W ATX12V v2.3 Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139019
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=11twlw4k16z17
Microsoft Windows 7 Home Premium SP1 64-bit English 1-Pack - OEM
http://www.newegg.com/Product/Produ...-na&AID=10521304&PID=4169961&SID=sn4bl2rge07l
when you click buy on the page of a good am3+ mobo, make sure on the left side where you can refine the search put the compatability one that has fx in it, otherwise upgrading to bulldozer, the point of am3+, isn't possible, after clicking buy there is a page asking to view shopping cart, under that there is the option to view all combos
Substitute?
Apparently this is out of stock is there a better or near the same Card like this?
Thats around the same price? Or should i just get this on another website.
Well there were more stuff that were out of stock so i substituted them with
SAPPHIRE 100328L Radeon HD 6770 1GB GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814102940
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
Now the total is 696$
Okay is the phenom 2 better than the cpu i showed?
is the Phenom 2 is that the right one or does it usually just fit any mobo also where can i find this am3+mobo combo
This AM3+ socket mb has nice features and the processor can be upgraded to the new line of processors down the road.
GIGABYTE GA-970A-D3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
This is the 955 processor I was referring to that is better than the 840 listed, for only a few bucks diff. (-10)
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
This memory is $34.(-10)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ
With the rest,
7 (-15)
WD Black
Corsair 600w
Case
Burner
= $532 w/o gpu
With the rest,
7 (-15)
WD Black
Corsair 600w
Case
Burner
= $532 w/o gpu
Thanks was the graphics card i showed in the post before decent?
Also what would be the most graphic intensive or close to that game this computer would be able to run If you know?
I think the 6770 will run current games at meduim settings @ 1080p.
If you can do a rebate you can get a 560 or 6870 and still be barely under $700.
a 6770 will run any game out today and for a little while, the res and detail and shading with the other settings is where it will be limited, but on any current game it will get close to if not max settings, depending on the game that is.
