The Sata cable is flat and thin. SATA power is flat and wide. IDE power is taller and has 4 pins that the connector slides over.
Oh yeah thats what I meant the IDE power, on my HDD what should I plug in? the SATA Power or IDE power?
if you have SATA power, then plug that in. The IDE power is for older systems with a controller card for SATA. Its not needed in your case.
AS5 all the way man.
and is yours custom built or prebuilt?
as5 is arctic silver 5. its a very good thermal paste.
really, you would be better off just buying the parts to build your computer. by the time that you get all your parts, 775 wont be able to keep up with anything modern. Sorta like 478 is now.
Even a cheap AM3 setup would be cheaper for you to do than the upgrade you have planed.
