win7 (64) blue screen help
astinkybumb
win7 (64) blue screen help (Solved)
i get this blue screen crash warning a couple times a day and i cant figure out what is causing it to crash. is there anything from this screen that im not getting that anyone can figure out or is there something i can do to detect what is causing the crash?
Ended up being bad ram. Thanks guys for the help!
jamesd1981
there are quite a few reasons you can get this screen, if you get a virus, if you windows files have became corrupt or missing, and if you have a hardware fault.
do you have a recovery method ? either a recovery partion or a windows disc ?
johnb35
Administrator
This is usally caused by bad ram. Have you added any recently? Please do the following so we can get a better look at your blue screens you've been having.
Download BlueScreenView
No installation required.
Unzip downloaded file and double click on BlueScreenView.exe file to run the program.
When scanning is done, go Edit>Select All.
Go File>Save Selected Items, and save the report as BSOD.txt.
Open BSOD.txt in Notepad, copy all content, and paste it into your next reply.
astinkybumb
- no viruses i scan regularly at least as far as im aware i dont have any.
- windows 7 is an upgrade from windows vista could this be the problem? however the computer seems touchy, some days it will crash 4 times in a few hours and some weeks i can leave it run downloading things and it wont crash once.
- i am running 8 gigs of ram currently (not sure the brand or anything off the top of my head) it was what i had installed when i configured the computer
i will download the blue screen thing and run it and re post the report
astinkybumb
BSOD.txt
Dump File : 070711-36785-01.dmp
Crash Time : 7/7/2011 6:07:49 PM
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c0000005
Parameter 2 : fffff800`02fae43d
Parameter 3 : fffff880`0ab91770
Parameter 4 : 00000000`00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+70740
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16695 (win7_gdr.101026-1503)
Processor : x64
Crash Address : ntoskrnl.exe+70740
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\070711-36785-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File Size : 291,944
Dump File : 070711-38298-01.dmp
Crash Time : 7/7/2011 3:54:18 PM
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Parameter 1 : fffff89e`80f476d8
Parameter 2 : 00000000`00000000
Parameter 3 : fffff800`031324c1
Parameter 4 : 00000000`00000005
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\070711-38298-01.dmp
Major Version : 15
Dump File Size : 295,848
Dump File : 070711-57377-01.dmp
Crash Time : 7/7/2011 3:32:53 PM
Parameter 1 : fffff89a`33846074
Parameter 3 : fffff800`030cd4c1
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\070711-57377-01.dmp
Major Version : 15
Dump File Size : 296,312
Dump File : 070611-51870-01.dmp
Crash Time : 7/6/2011 4:47:17 PM
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : fffffa80`1c262010
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000001
Parameter 4 : fffff800`02d96ac7
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\070611-51870-01.dmp
Major Version : 15
Dump File Size : 291,176
Dump File : 062711-55505-01.dmp
Crash Time : 6/27/2011 5:40:37 PM
Parameter 1 : fffffa80`0ca43010
Parameter 4 : fffff800`02d3dac7
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062711-55505-01.dmp
Major Version : 15
Dump File Size : 290,560
Dump File : 062711-58281-01.dmp
Crash Time : 6/27/2011 4:59:04 PM
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00005003
Parameter 2 : fffff700`01080000
Parameter 3 : 00000000`000000a6
Parameter 4 : 000000a8`7200014c
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062711-58281-01.dmp
Major Version : 15
Dump File Size : 262,144
Dump File : 062611-64724-01.dmp
Crash Time : 6/26/2011 8:10:57 PM
Parameter 1 : 00000000`00041790
Parameter 2 : fffffa80`001a52c0
Parameter 3 : 00000000`0000ffff
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062611-64724-01.dmp
Major Version : 15
Dump File Size : 291,936
Dump File : 062211-52229-01.dmp
Crash Time : 6/22/2011 5:27:40 PM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\062211-52229-01.dmp
Major Version : 15
Dump File : 061611-64740-01.dmp
Crash Time : 6/16/2011 3:04:03 PM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061611-64740-01.dmp
Major Version : 15
Dump File Size : 291,840
Dump File : 061311-67220-01.dmp
Crash Time : 6/13/2011 9:14:31 PM
Parameter 2 : fffffa80`00c47dc0
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061311-67220-01.dmp
Major Version : 15
Dump File : 061311-48422-01.dmp
Crash Time : 6/13/2011 9:05:50 PM
Parameter 2 : fffff800`02f5e606
Parameter 3 : fffff880`0b489ab0
Caused By Driver : Ntfs.sys
Caused By Address : Ntfs.sys+9fe45
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061311-48422-01.dmp
Major Version : 15
Dump File : 060911-55224-01.dmp
Crash Time : 6/9/2011 11:11:33 AM
Bug Check String : KMODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x0000001e
Parameter 1 : ffffffff`c0000005
Parameter 2 : fffff880`0bfae7b0
Parameter 3 : 00000000`00000000
Caused By Driver : atapi.sys
Caused By Address : atapi.sys+26d4
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060911-55224-01.dmp
Major Version : 15
Dump File : 060711-36987-01.dmp
Crash Time : 6/7/2011 5:00:04 PM
Parameter 1 : 00000000`00041287
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060711-36987-01.dmp
Major Version : 15
Dump File Size : 289,960
Dump File : 060611-44117-01.dmp
Crash Time : 6/6/2011 5:01:24 PM
Parameter 1 : fffffa80`1edd4010
Parameter 4 : fffff800`02d44ac7
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060611-44117-01.dmp
Major Version : 15
Dump File Size : 291,912
Dump File : 051911-46550-01.dmp
Crash Time : 5/19/2011 1:30:21 PM
Caused By Driver : fltmgr.sys
Caused By Address : fltmgr.sys+323f
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\051911-46550-01.dmp
Major Version : 15
Dump File Size : 291,640
Dump File : 051811-58500-01.dmp
Crash Time : 5/18/2011 7:04:16 PM
Parameter 1 : 00000000`00000401
Parameter 2 : fffff6fb`822003e0
Parameter 3 : 00000000`00000009
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\051811-58500-01.dmp
Major Version : 15
Dump File Size : 296,288
Dump File : 042811-52681-01.dmp
Crash Time : 4/28/2011 7:47:47 AM
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 2 : fffff800`02cc61dd
Parameter 3 : fffff880`0310f918
Parameter 4 : fffff880`0310f180
Caused By Address : ntoskrnl.exe+a71dd
Processor : x64
Crash Address : ntoskrnl.exe+a71dd
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042811-52681-01.dmp
Major Version : 15
Dump File : 042611-55083-01.dmp
Crash Time : 4/26/2011 6:14:41 PM
Parameter 2 : fffff800`02cc9b39
Parameter 3 : fffff880`06ff8150
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\042611-55083-01.dmp
Major Version : 15
Dump File : 041711-38641-01.dmp
Crash Time : 4/17/2011 6:44:23 PM
Parameter 1 : ffffdd80`06c10a50
Parameter 3 : fffff800`02ab72a9
Parameter 4 : 00000000`00000007
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\041711-38641-01.dmp
Major Version : 15
Dump File Size : 285,360
Dump File : 041711-55395-01.dmp
Crash Time : 4/17/2011 12:31:48 AM
Parameter 1 : fffffa80`249d6010
Parameter 4 : fffff800`02b84ac7
Caused By Address : fltmgr.sys+5fbc
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\041711-55395-01.dmp
Major Version : 15
Dump File : 041611-38298-01.dmp
Crash Time : 4/16/2011 7:37:17 PM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\041611-38298-01.dmp
Major Version : 15
Dump File Size : 291,720
Dump File : 041511-50279-01.dmp
Crash Time : 4/15/2011 10:27:53 AM
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\041511-50279-01.dmp
Major Version : 15
Dump File : 041411-38532-01.dmp
Crash Time : 4/14/2011 10:00:27 AM
Parameter 1 : fffffa80`24890010
Parameter 4 : fffff800`02b4bac7
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\041411-38532-01.dmp
Major Version : 15
Dump File : 041011-36987-01.dmp
Crash Time : 4/10/2011 8:43:59 PM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\041011-36987-01.dmp
Major Version : 15
Dump File Size : 291,920
Dump File : 040711-50201-01.dmp
Crash Time : 4/7/2011 9:50:40 PM
Parameter 2 : fffffa80`01507500
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\040711-50201-01.dmp
Major Version : 15
Dump File : 032911-46441-01.dmp
Crash Time : 3/29/2011 11:45:27 AM
Parameter 1 : fffff8a0`b8599a74
Parameter 3 : fffff800`02d6343d
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032911-46441-01.dmp
Major Version : 15
Dump File : 032811-44928-01.dmp
Crash Time : 3/28/2011 6:53:05 PM
Parameter 1 : fffff961`2030c7e8
Parameter 3 : fffff960`000c5750
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032811-44928-01.dmp
Major Version : 15
Dump File : 032311-34725-01.dmp
Crash Time : 3/23/2011 12:55:31 PM
Parameter 1 : 00000000`00005005
Parameter 3 : 00000000`000001eb
Parameter 4 : 00000000`000001ec
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032311-34725-01.dmp
Major Version : 15
Dump File Size : 291,656
Dump File : 032311-36722-01.dmp
Crash Time : 3/23/2011 2:56:48 AM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032311-36722-01.dmp
Major Version : 15
Dump File : 032111-35864-01.dmp
Crash Time : 3/21/2011 3:08:39 PM
Parameter 1 : 00000000`00041201
Parameter 2 : fffff683`ff791440
Parameter 3 : 00000000`00000005
Parameter 4 : fffffa80`06ebfd60
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032111-35864-01.dmp
Major Version : 15
Dump File Size : 291,952
Dump File : 031811-51745-01.dmp
Crash Time : 3/18/2011 5:46:36 AM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\031811-51745-01.dmp
Major Version : 15
Dump File : 030211-41433-01.dmp
Crash Time : 3/2/2011 11:22:01 PM
Parameter 1 : fffffa80`24867010
Parameter 4 : fffff800`02b47ac7
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\030211-41433-01.dmp
Major Version : 15
Dump File : 030111-38189-01.dmp
Crash Time : 3/1/2011 8:31:15 PM
Parameter 1 : fffffa80`028a1630
Parameter 3 : fffff800`02ad3b1c
Parameter 4 : 00000000`00000002
Caused By Address : Ntfs.sys+b3d89
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\030111-38189-01.dmp
Major Version : 15
Dump File : 022511-39234-01.dmp
Crash Time : 2/26/2011 12:09:41 AM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\022511-39234-01.dmp
Major Version : 15
Dump File : 021811-35271-01.dmp
Crash Time : 2/18/2011 2:06:48 PM
Bug Check String : DRIVER_VERIFIER_IOMANAGER_VIOLATION
Bug Check Code : 0x000000c9
Parameter 1 : 00000000`0000023e
Parameter 2 : fffff880`03f3e308
Parameter 3 : fffffa80`07029ee0
Caused By Driver : dtsoftbus01.sys
Caused By Address : dtsoftbus01.sys+1308
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021811-35271-01.dmp
Major Version : 15
Dump File Size : 291,624
Dump File : 021811-37627-01.dmp
Crash Time : 2/18/2011 2:03:08 PM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021811-37627-01.dmp
Major Version : 15
Dump File : 021711-42541-01.dmp
Crash Time : 2/17/2011 7:24:40 PM
Parameter 1 : fffffa80`832b2184
Parameter 3 : fffff880`0103cdbe
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021711-42541-01.dmp
Major Version : 15
Dump File : 021511-46457-01.dmp
Crash Time : 2/15/2011 7:34:12 PM
Bug Check String : NTFS_FILE_SYSTEM
Bug Check Code : 0x00000024
Parameter 1 : 00000000`000c08a2
Caused By Address : Ntfs.sys+1e95
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021511-46457-01.dmp
Major Version : 15
Dump File : 020211-41168-01.dmp
Crash Time : 2/2/2011 3:54:44 PM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\020211-41168-01.dmp
Major Version : 15
Dump File : 012811-24897-01.dmp
Crash Time : 1/28/2011 3:12:28 PM
Parameter 1 : fffff900`b80b7968
Parameter 3 : fffff800`02c067ca
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\012811-24897-01.dmp
Major Version : 15
Dump File Size : 291,816
Dump File : 012811-39717-01.dmp
Crash Time : 1/28/2011 11:31:03 AM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\012811-39717-01.dmp
Major Version : 15
Dump File Size : 295,960
Dump File : 012111-48375-01.dmp
Crash Time : 1/21/2011 10:22:43 AM
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\012111-48375-01.dmp
Major Version : 15
Dump File Size : 284,448
johnb35
Administrator
Not sure how I missed this thread but yes, definately you have a ram issue. All the sticks may be bad or only one stick. You should download and run memtest on each stick one at a time to determine which sticks are bad.
http://memtest86.com/memtest86-4.0.iso.zip
It's a zipped ISO, so you will need to unzip and then use burning software to actually write the ISO to a cd and then boot to the cd and it will automatically start testing the ram that is installed.
old_school
This is a RAM issue, starrt pulling sticks one at a time till the error goes away. It basicly tells you in the logs its memory issue. Anything Page fult related or memory managment is typically RAM related. You might also tinker with your BIOUS settings to ensure its setup correctly.
the_tds02
hi there guys sorry for asking about a problem on someone elses thread.im having the same problem with windows 7 ultimate 64 bit.although doesnt seem to happen that constant it is still very annoying when it does happen.ive done a bsod txt and here are the results,if someone could help me out it would be very much appreicated.
Dump File : 072411-22978-01.dmp
Crash Time : 24/07/2011 19:24:54
Bug Check String :
Bug Check Code : 0x00000109
Parameter 1 : a3a039d8`99a4b64c
Parameter 2 : b3b7465e`ec22dfe6
Parameter 3 : fffff880`00cfa778
Parameter 4 : 00000000`00000001
Caused By Driver : CLFS.SYS
Caused By Address : CLFS.SYS+2d778
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7fd00
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\072411-22978-01.dmp
Major Version : 15
Minor Version : 7601
Dump File Size : 385,728
Dump File : 072211-18064-01.dmp
Crash Time : 22/07/2011 19:34:54
Bug Check String : BUGCODE_USB_DRIVER
Bug Check Code : 0x000000fe
Parameter 1 : 00000000`00000006
Parameter 2 : fffffa80`09df9068
Parameter 3 : 00000000`48706950
Caused By Driver : USBPORT.SYS
Caused By Address : USBPORT.SYS+2d27d
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\072211-18064-01.dmp
Major Version : 15
Dump File Size : 385,656
Dump File : 071711-45240-01.dmp
Crash Time : 17/07/2011 19:11:34
Bug Check String : BAD_POOL_HEADER
Bug Check Code : 0x00000019
Parameter 1 : 00000000`00000020
Parameter 2 : fffff8a0`0a8ede10
Parameter 3 : fffff8a0`0a8edea0
Parameter 4 : 00000000`0c09d088
Caused By Address : ntoskrnl.exe+7fd00
File Version : 6.1.7601.17592 (win7sp1_gdr.110408-1631)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\071711-45240-01.dmp
Major Version : 15
Dump File Size : 380,264
Dump File : 071211-26676-01.dmp
Crash Time : 12/07/2011 16:53:54
Parameter 1 : 00000000`00000049
Parameter 4 : fffff800`02c78891
Caused By Address : ntoskrnl.exe+70700
Processor : x64
Crash Address : ntoskrnl.exe+70700
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\071211-26676-01.dmp
Major Version : 15
Dump File Size : 285,000
Dump File : 071111-28641-01.dmp
Crash Time : 11/07/2011 18:24:42
Parameter 1 : 00000000`00000003
Parameter 2 : fffff8a0`0ab66260
Parameter 3 : fffff8a0`0ab66260
Parameter 4 : 6446744e`00060309
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\071111-28641-01.dmp
Major Version : 15
Dump File Size : 282,424
thanks again
johnb35
Administrator
Some are pointing toward driver related issues and others pointing to memory issues.
So first off, make sure all drivers are up to date and then test your memory with memtest86 by making a memtest cd and booting to it.
http://www.memtest86.com/memtest86-4.0.iso.zip
Unzip the file to get to the actual ISO file and then use burning software to write the image file to cd and then boot to it.
the_tds02
hi there thanks for reply.ive done a scan using driver detective trial and it seas there are outdated drivers mainly my chipset i think.ive got a intel5 series/3400 chipset.im just wondering where the best place to get the drivers from,ive checked intel website and to be honest i dont know what i need.thanks
mep916
Administrator
http://downloadcenter.intel.com/
Use the driver utility prominently displayed on the top of that page, or use the menu. You'll need the exact model number for the menu.
johnb35
Administrator
Do you have the model of computer you are using or model of motherboard if its a custom built pc?
mep916
Administrator
so i downloaded unzipped and booted the iso in daemon tools now where do i navigate to install?
For memtest86 (I'm assuming that's what you're referring to), you need to burn the ISO to a blank CD, then restart your PC and boot into memtest86. It will run automatically, just be sure you have your CD drive set to boot first in the disk priority in the BIOS.
As others have stated, for best results, you should test one RAM stick at a time. If you have every stick installed and receive errors, you'll have no idea which stick is faulty.
