for some reason i can't get itunes to open, i have deleted program and tried re-installing and it still doesn't work, does anybody know what the problem could be
download the latest version, make sure you check if you're 32 or 64-bit operating system.Just say itunes installs in c:\program files by default make a new folder in c:\ call it whatever you want and install itunes their.You might have to right click on the itunes shortcut and change it to one of the service packs.Try running itunes as an administrator.Hope this helps
