That's the amount of video RAM between the dedicated (which is probably 512MB) and the shared system RAM that is being used for graphics at that time. Therefore, that number may come out different every time you run that test as Windows is constantly adjusting how much that it allocates to graphics depending on what is being run at the time...
Hmm..., ok, I looked up the specs on that card and it had 2GB of onboard RAM. So depending on how that card was built, some of the RAM may have gone bad or something, not sure - getting beyond my knowledge of how the boards are manufactured. Have you tried rebooting the computer and rerunning the scan?
I just did a quick run on mine which only has 512MB of onboard RAM and it says that I have 2.2GB of RAM, so I wonder if there's something a little messed up with how the site detects the video RAM...
2287, so that's probably where they get the info from and it could cause some incorrect reporting because I do believe that particular screen does pull both physical and virtual video RAM. As for the X2 part of your card, I believe that took it from 1GB to 2GB which is what specs say that card has. Might want to do a disk error check and see if that corrects the issue if the reboot doesn't.
Alright thank you, I'll try it when I get home. Which disk will that check?
Your C: drive. You can change it to another if you need.
