guy.joseph
Hi
I have just received a RAID card in the post today.
It was this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220761288509&ssPageName=STRK:MEWAX:IT one
I want to use it with my 4 500gb hard drives to create a RAID 0 array of 2 TB.
I set it up with the auto configuration and then installed Windows (Vista Home Premium x32).
Before I installed the card, I benchmarked each of the drives, and all of them gave at least 100MB/s I/O rate.
Now, the array is averaging 10 MB/s, using the same benchmark!
The idea of using RAID 0 is to increase speed - I was looking for at least a 2x increase but I've got a 10x decrease!
What is going wrong?
Thanks
Guy Joseph
- Is the card not up for it?/Too cheap?
- Is the speed limited by the PCI bus that the card uses?
- Is it that I'm not using identical disks for all the drives (they are all 500GB)
- Is it a problem in setup/chunk size/Windows Installation?
- Is there something else?
Thanks
Guy Joseph
