After much thought i decided to build my own computer Largely due to the fact Cyberpower wouldn't of shipped my PC till the first of next month(order was placed 3 weeks ago).
i was hoping you share your options on the parts i choice for my build here
Case: cooler master Half 932 Adanced Rc 932-kkn5-gp
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
CPU: Intel Core I7-600 3.4HGz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071 (fixed)
Motherbored: ASUS P8Z68 PRO LGA 1155 Intel Z68
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
aftermarket heatsink: Corsair CWCH60 Hydro series H60
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015
Thermal Compound: Arctic Silver 5 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Video Card: EVGA Superclocked 01f-P3-1563Ar Geforce GTX 560 TI Fermi 1G
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
OS: Microsoft Windows 7 Professional SP1 64-BIT- OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116992
Optical drive: Samsung Black 12X BD-Rom
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222
Power Supplier: Corsair Professional Series Hx750 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Ram: Corsair Vengeance 8G (2 x 4 GB) 240 Pin DDR3 SDRAM DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
SSD: Corsair Nova Series 2 CSSD-V60Gb2 2.5 60BG SATA II
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233188
Round total came out to 1501 a heavy chuck of change but worth it if i dont have to upgrade anything but the video card in the next 6 years. My major question is do i need to order anything else?
i have taken Computers Apart (mostly my own) for years but never build one after doing alot of research i found out its not what it was 10 years ago and should be relatively easy to put together
First did i forget to order anything i will need?
second are any of the parts subpar or can i get better for next to same price?
any and all options welcome thank you again!
