Transfer windows 7 OS from laptop to desktop
CarbonShock
I currently have a laptop with windows 7 and I am looking at getting a desktop but don't want to buy windows 7 again.
Can anyone tell me of a way to transfer windows 7?
You won't be able to transfer OS from a laptop to a custom built machine. You will have to buy a new Operating system.
If the laptop has a Retail version of 7, which I doubt, then it could be done as long as the operating system is completely removed from the laptop and all media and paper work is passed to the new owner which in theory is Carbon.
This can be done on a one time basis only.
If Windows 7 came pre-installed then it is an OEM and not transferable in any way and a new OS has to be purchased.
Does that mean I can't or is it slightly different based on my last post?
If you have a sticker on the laptop showing the product key then you have an OEM version of Windows 7 and as I mentioned earlier it is not transferable.
But you said this Carbon.
What exactly does it say on the Windows 7 disk that you have?
when I said that I meant that the key was in use on that laptop and I can't seem to be able to find the disk at the moment. If I manage to find it I will post what it says on the sticker.
If its an OEM version of Windows 7 that you installed on the laptop, you can't transfer it to the desktop. If it's a retail version of Windows 7 then you can transfer it, however, you would have to uninstall windows 7 from the laptop.
Well, what would probably happen is a phone call to MS where they would activate the key onto the desktop. When/if he boots into the laptop, he'd be placed into reduced functionality mode and asked for a legit product key, since the key has now been transferred to the desktop. I don't think he'd have to reformat/erase the windows installation from the laptop before installing on the desktop. Not in my experience transferring OS licenses anyway.
That's all assuming it's a transferable retail version.
I'm just trying to teach them the correct and legal way to do it, as you know.
It's more of a shortcut, and not necessarily illegal. It would be unfortunate if he formatted the laptop, installed this version on the desktop to find it can't be transferred. It would be a waste of time, actually.
It can be transferred as long as its a retail version of windows, not an OEM. Most users buy OEM these days cause its cheaper then buying the full version. I'm also certain its the same with an upgrade version.
Right, and both methods are correct. John's method is definitely the textbook way Microsoft would prefer you to do it, I've just bypassed that over the years. I wasn't trying to imply that you were wrong or whatever John. :)
If there is no sticker on the laptop there can only be three scenario's.
1: The install is OEM but the sticker has not been applied yet for whatever reason.
2: The install is Retail and therefore the key is on the packaging.
3: The install disk is pirate and has the key physically written on the disk.
Let us assume that Carbonshock does indeed have a Retail version installed on the laptop it would be then reasonable to assume that it has had been activated.
I also believe that Carbon does not want to remove the install from the laptop so as has been mentioned the only course open is for him to buy another copy of 7.
I wouldn't mind removing windows 7 from my laptop and I have found the disc but can't see anywhere if it is OEM or retail
