Wolfeymole
What does it say on the disk Carbon?
You are correct that you cannot use it as it is an OEM.
You will have to buy either a Retail or unbranded OEM version of 7 if you want to install it to the new machine.
Sorry mate.![]()
You're more than welcome.
If you are thinking of buying a branded machine it will come with an operating system already installed similar to the laptop.
Will the new machine be branded or hand built by a shop?
