Memory Reccomendation for Acer TimelineX. G.Skill vs Corsair vs Samsung Vs Kingston.
Which memory brand would you reccommend?
  • Total voters
    7
AcerTimeLineX
What are your thoughts on how these specific laptop memory models below stand up against each other, which brand would you suggest? Reliability and stability is important, I don't want blue screens and freezes.
Also is PC3-10600 vs PC3-10666 just marketing lingo, or does PC3-10666 really improve speed compared to PC3-10600?
Also price is not a big factor, all the modules except for Samsung are around the same price, maybe 10 dollar difference. Samsung says RoHS compliant, not sure what that means!
Thanks for your opinions!
1) G.SKILL 8GB (2 x 4GB)
204-Pin DDR3
SO-DIMM DDR3 1333 (PC3 10666)
Laptop Memory Model F3-10666CL9D-8GBSQ
Cas Latency:9
Timing:9-9-9-24
Voltage:1.5V
ECC:No
Buffered/Registered:Unbuffered
Multi-channel Kit: Dual Channel Kit
Parts:Lifetime limited
Labor:Lifetime limited
Price $39.99
2) CORSAIR 8GB (2 x 4GB)
204-Pin DDR3
SO-DIMM DDR3 1333 (PC3-10600)
Laptop Memory Model CMSO8GX3M2A1333C9
Cas Latency:9
Timing:9-9-9-24
Voltage:1.5V
Price $43.99
3) Kingston 8GB (2 x 4GB)
204-Pin DDR3
SO-DIMM DDR3 1333 (PC3 ??? Doesn't say if its 10600 or 10666)
Laptop Memory Model KVR1333D3SOK2/8GR
Cas Latency: 9
Timing: Can't find that information
Voltage:1.5V
ECC: No
Labor: Lifetime limited
Price $ 54.99
4) SAMSUNG 8GB (2 x 4GB)
204-Pin DDR3 SO-DIMM DDR3 1333 (PC3 10600)
Laptop Memory Model MV-3T4G4D/US
Cas Latency: 9
Timing:9-9-9-24
Voltage:1.5V
ECC:No
Features:Very Low Profile 100% Genuine Samsung Memory RoHS Compliant
Price: $88.99
I have G.Skill Ripjaws X Series 8GB and I really like them. However, mine is 1866 instead of 1333, but I would still recommend them.
Also, isn't it 240 pin? If not you might want to check compatibility with your motherboard.
He needs 204-pin for his laptop.
As for the RAM, all of them are pretty similar. Same speed, timing, and voltage. I would go for corsair or G. Skill.
