Help! Does this fit together!?
where are you ordering from? and cooler master is a bad brand, you want a corsair/seasonic/silverstone/ocz/antec/ and a few others, but tell us you budget and we'll tell you what to get, along with what country you're in, but you'll also need an os disk unless you plan to use ubuntu which can be difficult to run but is free and has a marketplace style thing full of free apps.
im in the uk, and my budget is £270, i know pretty tight but im going to upgrade soon, and that psu will do the trick for a month or 2, and i already have windows 7, on a disk:)! thanks dude
would be a lot smarter to save up more then instead of upgrading and wasting money now, just get a beast in a month to 3 and by then bulldozer should be out, of course it is also starting just bellow 200 usd
ahaha, okay! but could you tell me if the memory will fit with the mobo in the components above?:D
Cooler Master isn't bad! They make awesome PSU's!
i've been told different by others, i think bigfella was 1, andidk who else, but really depends on the series and luck with some of the cheaper ones.
