DrSlickDaddy
Hi. I have been having some serious problems with my PC lately. I am running Windows 7 Home Premium 64 bit. It started when in games the games would suddenly drop in fps to about 0-10 fps while they were usually running about 60fps. When the game started lagging like this, both of my GPU's had a usage of about 20% (running in Crossfire) and the temps would drop about 5 degress and then stop lagging. Once they reached around 70 degrees Celsius it would lag again and stop once the temps dropped. I also had a problem where the screen would flicker/flash black every now and then. After about 20 minutes or so my computer would blue screen and this happened every time I played games. I "fixed" this by disabling crossfire therefore only using one GPU. Every game ran a lot better. There was no longer the lag problems. I played a game for about an hour and then it blue screened without crossfire and gave me the same details as with crossfire enabled (i'll put that at the end). I'd also like to note that the GPU ran significantly cooler (50 degrees celsius) when crossfire was disabled. With and without it enabled I also had blue screens when simply browsing the internet (again, same error codes). I assumed it was my display drivers so i uninstalled them using Driver Sweeper and as I was on the internet looking to download new drivers it blue screened. So what I established from that is that it is not the drivers thats causing the problem and at this point I'm lost. I'll post the mini dumps and error details below.
Computer Specs:
AMD Phenom X6 II 1090t 3.2GHz
x2 Ati Radeon 5750's 1GB DDR5 Crossfire
4GB DDR3 RAM
XtremeGear 800w Power Supply
Windows 7 Home Premium 64 Bit
ASUS M4A87TD EVO 870
BlueScreen:
Problem Signature:
Problem Event Name: BlueScreen
Locale ID: 1033
Additional Information about this problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA8005759028
BCP3: 00000000B6002000
BCP4: 00000000D4000135
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Computer Specs:
4GB DDR3 RAM
BlueScreen:
Problem Signature:
Locale ID: 1033
BCCode: 124
Service Pack: 1_0
Product: 768_1
