Tom_Howard
Instead of building a PC I decided to go with a local shop that does custom PC's. My new PC will have 16GB of RAM, is this considered too much for day to day tasks?
8GB is plenty for gaming and heavy multitasking, you would only need more for something like CAD or video editing on a large scale. Plus RAM is cheap (and always getting cheaper) and easy to install so you can always upgrade later if needed.
It was only $80 to go from 8 to 16GB, so its definitely cheap.
I second this, you would benefit far more from an SSD than putting 8GB more RAM in your system that will, in all likelihood, go completely unused.I think you would be much better off putting that $80 towards an SSD,or if you already have an SSD in mind on your build list put the $80 towards a bigger SSD.
hey, if he's got the money then he can get all the ram he wants just to say a bigger number
and 4 is plenty for nearly anyone, 8 is overkill for most, even for a good number of gamers, 12 is plenty for real workstations, and 16+ is only needed for people ultra-tasking with video creation or coding
