Hello everybody ive decided to make my own computer and ive come up with a component list for a gaming computer and im wondering mainly if there are any suggestions for the build and also if it will work + is the intel i7s hyperthreading any use for gaming purposes but without any more suspense here is the list:
Motherboard:Gigabyte Z68XP-UD5 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard GA-Z68XP-UD5
Link: http://www.msy.com.au/product.jsp?productId=7863
Powersupply: Corsair Professional Series Gold High-Performance 850-Watt Power Supply CMPSU-850AX
Link: http://www.amazon.com/Corsair-Profe...-Watt-CMPSU-850AX/dp/B003PJ6QW4/ref=pd_cp_e_1
Processor: Intel Core i7 2600K
Link: http://www.pccasegear.com/index.php?main_page=product_info&cPath=187_346_1184&products_id=16416
RAM: G.Skill Ripjaws X F3-17000CL9D-8GBXM (2x4GB) DDR3
link: http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_912&products_id=17938
Graphics card: Note that im planning to upgrade this or get a second card
iamond AMD Radeon HD 6970 2GB GDDR5 PCI-Express Graphics Card 2 DVI / HDMI / 2 Mini Display Port Eyefinity
Link: http://www.amazon.com/Diamond-PCI-E...?s=electronics&ie=UTF8&qid=1312700552&sr=1-49
Hard Drive: WD 3.5" Black 2TB WD2002FAEX SATA3 7200rpm HDD
Link: http://www.msy.com.au/product.jsp?productId=7299
Case:NZXT Crafted Series ATX Full Tower Steel Chassis - Phantom Black
Link: http://www.amazon.com/NZXT-Crafted-Tower-Steel-Chassis/dp/B003WE9WQY/ref=pd_cp_e_3
Optical drive
ioneer DVR-219L DVDRW OEM
Link: http://www.pccasegear.com/index.php?main_page=product_info&cPath=658_667&products_id=16397
Os: windows 7 home premium 64bit
i think you all know what home premium is
Optical drive
