clquestor
You guys are awesome thanks for the feedback. I'll see what I can do with it for now. Hopefully I can play it at somewhat enjoyable settings. If it plays/looks horrible I'll just wait a couple months. Also to respond to taking my rig out of the case, the GTS 250 requires a core2-duo and up to run I believe. In which case my Pentium D can't handle it I assume.
Actually guys I see that the 4350 is the way you're all going...does that mean that my 210 w/ 1 gig ddr3 has no real advantage over 4350 with 512 ddr2? Is it just not a deciding factor in this case or is dedicated video memory over 512 not a huge difference? Is it the fact that they're both 64 bit? What if I found a really cheap 128 bit...any chance of that performing better?
