Windows 7 Annoying Administrator Shield On Icon
Trance
Hi!
So i just used a program called registry easy, its for cleaning registry files.
I found an interesting tab in program called optimize system.
So I accidently used it and now there are those stupid ugly blue yellow admin shields on almost every icon. I have UAC disabled but how can i get rid of these shields, I am administrator of that computer.
Ive been looking for solutions everywhere but i havent found any.
So yeah can anyone tell me how i can get rid of these shields or even better roll back the changes what i made with optimize system.
Thanks, Trance!
not yet, i try it thanks
EDIT: It didnt worked theyre still there, i restarted and everything
You most likely have malware on your system. Please do the following.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
johnb wtf, how has this anything to do with a malware and in my last thread you said me excatly the same story, wtf?
I don't keep track of the threads each user makes. Most odd ball registry programs on the net are actually rogue malware programs.
You don't need to install a registry program for one. You are asking for problems anyway. The only cleaner program you need is Ccleaner. But do you what you want. Just trying to keep you from having headaches as in this case.
hv man, i cant make myself the system restore point my sh*t computer wont let me. Any ideas?
Are you sure right click my computer > properties > system protection > click system restore > click next > then show more restore points if there is one before the problems started occurring restore to that point.
Also please be nicer to john he could be right and that program you used could possibly have contained malware.
The System Restore button is greyed out, btw i got avast! internet security if avast even blocks harmful sites then im quite sure it wont let any viruses through, and if theres a suspect program it will run it in sandbox.
Ive already done this step john recommends like 2-3 times.
Sounds like malware alright. Do as john posted, and don't use registry programs, they are worthless. The only I would trust is CCleaner.
i dont get it how can it be a malware, only thing changed in my computer is those god deamn admin shields before icons, they are just visual and i wanna get rid of them.
and i´ve never had system restore on because i just cant make it, its like that straight after i brought it home from shop
Either use Ccleaner to thoroughly remove all traces of the program, or do some googling on how to manually remove it. Does the problem still occur in Safe Mode? If not, identify which service the program is running.
If the problem persists, malware is very probably - any program that hides itself from an uninstall / manual removal is malware, to me.
Safe mode > Download and update malwarebytes > full scan > restart
First, Registry Easy is the clone of known rogueware "Registry Great", please check the following page:
http://www.411-spyware.com/remove-registry-great-v5-0
http://www.spywaredetector.net/spywa...ry Great.htm
http://www.pcthreat.com/parasitebyid-6838en.html
And there is a page that tell us how to remove Registry Easy:
http://www.scanspyware.net/info/RegistryEasy.htm
So, we can confirm that Registry Great is a fake registry cleaner too, it gives misleading result to get users to purchase it. Full of fake errors and alarm, it's a rogueware. IN actual fact its scareware, requiring your to pay for it if you want the changes undone.
Settle down with the profainity mate, and to be honest, Trance you own an apology to John imho. That was the first thing i thought of too. Many malware distributes use 'likely sounding' 'helpful' software as a way to get the malware on your system. Over 80% of malware requires user acceptance and in this case I suggest you scan your system as you've been pwned!
