Basically there are things that I understand and some things that I don't and some others I just want opinions.
First off,
What do you look for when choosing a PSU. I know you should go as big as you can afford but what other aspects should I look for other than Wattage?
Another thing is that some GPU's say DDR5 but I have not found a motherboard that says that? How do you determine what mobo can run those.
Also I have been looking at some CPU's and can't determine what makes a good one. Other then after choosing your mobo, should I choose a CPU first? I have been looking at the Intel i7 and the AMD Phenom 2 1100T. Any opinions.
Soon enough I will give you guys a full list of my options, overall what I hope to do is get the best I can now so that in the future I can upgrade individual components when I get the money.
First off,
