My computer seems to have some corrupt files or bad sectors on the hard drive. The computer runs perfect once you get it going and I rarely turned it off for this reason, but its now reached a point where windows simply wont boot. HP want to replace the hard drive, and they can, but I just need to get it booted once so I can back up my personal files first. The problem is, I dont have a Windows DVD. The OS is located on a partition on the hard drive and without access to windows I cant make a recovery disk. I have done some searching, but I cant find dedicated W7 files to make a boot disk. Im not even sure this will help. I can always remove the drive and put it in another PC and copy files that way but I may void the extended warranty Im paying for. HP want to make life as quick and easy as possible for their technicians so swapping the drives is a 5 minute job and they take the bad one with them, which doesnt help me in the slightest. Thanks HP. The system just keeps running disk scans and its finding unreadable sectors. What other options do I have?? This really sucks as I was only a day away from buying an external back up drive and there are heaps of things in that bad drive I need. Cheers JB
