How do you add the google search box to your internet browser?
You can also direct search in your URL bar, if you don't add a .com to the end.
That is the best way if you are using chrome, other browsers would use the default search engine. Like IE will use Bing.
Chrome also has suggestions when typed in the URL bar. :)
