Ram usage increases steadly????
Why does my Ram usage continue to rise while I use the PC. Once the PC is started the RAM is at 36% but once on the PC for an hour or so it goes up to 58 or 59 %. No mater what I shut down (IE, MS Word, etc) it will never go back to the 36% it started with.
Can anyone help with this, it seems to be slowing down the machine.
The PC is a Dell Studio 540
6 Gig of RAM
Intel Core 2 Quad Q8300 2.5Ghz
Windows Vista Home Premuim SP 2 64 bit
Thanks
well remeber that it loads in the graphics drivers, virus stuff, and a ton of other background programs, also you may just have a ton of bs from lack of maintnance, uninstalling unused old apps may help some, idk what else cuz my win7 with only 3gb's ram stays at ~56% all the time, and also sometimes i think it will leave programs like ie in the ram since you are likely to use it a lot.
You may be infected so do the following to scan for malware.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Ok here are the results from Malwarebytes log. I will post the log for Hijack this shortly.
Malwarebytes' Anti-Malware 1.51.2.1300
www.malwarebytes.org
Database version: 7711
Windows 6.0.6002 Service Pack 2
Internet Explorer 9.0.8112.16421
13/09/2011 9:03:55 PM
mbam-log-2011-09-13 (21-03-55).txt
Scan type: Quick scan
Objects scanned: 180618
Time elapsed: 3 minute(s), 37 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Folders Infected:
Files Infected:
on a side note, do you ever do maintnance such as disk error checks and defragmentation, these are most likely not the issue with this but they can greatly increase performance in same cases.
Getting the following message when I try to run Hijack scan
HijackThis
For some reason your system denied write access to the Hosts file. If any hijacked domains are in this file, HijackThis may NOT be able to fix this.
If that happens, you need to edit the file yourself. To do this, click Start, Run and type:
notepad C:\Windows\System32\drivers\etc\hosts
and press Enter. Find the line(s) HijackThis reports and delete them. Save the file as 'hosts.' (with quotes), and reboot.
For Vista: simply, exit HijackThis, right click on the HijackThis icon, choose 'Run as administrator'.
OK
Doing a defrag now but its been running for more than 8hrs. I guess it was well overdo. Is there a way to see the defrag progress in Vista.
depends on what you use, and also running other programs isn't advised while defragging, or at least to me, since it can cause more defragging and just seems like it could screw it up some more, also this might not be helping with the hijack stuff.
HijackThis
OK
You need to right click on the hijackthis icon and click on "run as". If the run as option doesn't appear then press and hold the shift key while right clicking on hijackthis to get it to appear.
Also, as suggested, you shouldn't be doing anything while defragging. Vista defrag actually sucks, I would suggest to use defraggler.
http://www.piriform.com/defraggler
Ok here is the log.
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 9:44:41 PM, on 13/09/2011
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v9.00 (9.00.8112.16421)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Norton 360\Engine\3.8.0.41\ccSvcHst.exe
C:\Program Files (x86)\Dell DataSafe Online\DataSafeOnline.exe
C:\Windows\vVX1000.exe
C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Program Files\CyberLink\PowerDVD DX\PDVDDXSrv.exe
C:\Program Files (x86)\HP\HP Software Update\hpwuSchd2.exe
C:\Program Files (x86)\HP\Digital Imaging\bin\HpqSRmon.exe
C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
C:\Program Files (x86)\WD\WD Anywhere Backup\MemeoBackup.exe
C:\Program Files (x86)\internet explorer\iexplore.exe
C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbarUser_32.exe
C:\Program Files (x86)\Microsoft\Search Enhancement Pack\SCServer\SCServer.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil10w_ActiveX.exe
C:\Program Files (x86)\Sonos\sonos.exe
C:\Program Files (x86)\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www1.ca.dell.com/content/default.aspx?c=ca&l=en&s=gen
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.hotmail.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www1.ca.dell.com/content/default.aspx?c=ca&l=en&s=gen
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer provided by Dell
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
O1 - Hosts: ::1 localhost
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Symantec NCO BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton 360\Engine\3.8.0.41\coIEPlg.dll
O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton 360\Engine\3.8.0.41\IPSBHO.DLL
O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files (x86)\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O3 - Toolbar: Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton 360\Engine\3.8.0.41\coIEPlg.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O4 - HKLM\..\Run: [PDVDDXSrv] "C:\Program Files\CyberLink\PowerDVD DX\PDVDDXSrv.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Windows\system32\NeroCheck.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files (x86)\HP\Digital Imaging\bin\hpqSRMon.exe
O4 - HKLM\..\Run: [LifeCam] "C:\Program Files (x86)\Microsoft LifeCam\LifeExp.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [WD Anywhere Backup] "C:\Program Files (x86)\WD\WD Anywhere Backup\MemeoLauncher2.exe" --silent
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] "C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe" /install /silent
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [swg] "C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - .DEFAULT User Startup: Dell Dock First Run.lnk = C:\Program Files\Dell\DellDock\DellDock.exe (User 'Default user')
O4 - Startup: Dell Dock.lnk = C:\Program Files\Dell\DellDock\DellDock.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_7461B1589E8B4FB7.dll/cmsidewiki.html
O9 - Extra button: @C:\Program Files (x86)\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1004 - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: @C:\Program Files (x86)\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1003 - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O18 - Protocol: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - C:\Program Files (x86)\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll
O18 - Protocol: symres - {AA1061FE-6C41-421F-9344-69640C9732AB} - C:\Program Files (x86)\Norton 360\Engine\3.8.0.41\coIEPlg.dll
O18 - Protocol: wlpg - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\Windows\system32\browseui.dll
O23 - Service: Andrea RT Filters Service (AERTFilters) - Unknown owner - C:\Windows\system32\AERTSr64.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files (x86)\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: @dfsrres.dll,-101 (DFSR) - Unknown owner - C:\Windows\system32\DFSR.exe (file missing)
O23 - Service: Dock Login Service (DockLoginService) - Stardock Corporation - C:\Program Files\Dell\DellDock\DockLogin.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: LMIGuardianSvc - LogMeIn, Inc. - C:\Program Files (x86)\LogMeIn\x64\LMIGuardianSvc.exe
O23 - Service: MemeoBackgroundService - Memeo - C:\Program Files (x86)\WD\WD Anywhere Backup\MemeoBackgroundService.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: Norton 360 (N360) - Symantec Corporation - C:\Program Files (x86)\Norton 360\Engine\3.8.0.41\ccSvcHst.exe
O23 - Service: NBService - Nero AG - C:\Program Files (x86)\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NMIndexingService - Nero AG - C:\Program Files (x86)\Common Files\Ahead\Lib\NMIndexingService.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: PnkBstrA - Unknown owner - C:\Windows\system32\PnkBstrA.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\SLsvc.exe,-101 (slsvc) - Unknown owner - C:\Windows\system32\SLsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
End of file - 11678 bytes
Rerun hijackthis and place checks next to the following entries.
O4 - HKCU\..\Run: [swg] "C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNo tifier.exe"
Then click on fix checked at the bottom.
I also recommend doing yourself a favor and getting rid of Nortons and downloading either Microsoft Security Essentials or Avast antivirus. Norton 360 can be a resource hog and is most likely your issue.
which i said this efore, but i'm currently running win7, chrome (with pandora open), norton 360, steam, and a few other things in the background and i'm only using like 56% of my 3gb's.
You are running windows 7, he's running Vista as vista uses a lot of memory all by itself. There also will be a difference from pc to pc.
and i do try to keep mine as up-to-date (driver wise) and maintained with defrags and such as possible, so that prob helps too
Ok, checked all except,
I use this software to manage my drive back-up.
That's fine. I kind of figured you did, but not a lot of users use backup software.
Also check your task manager to find out what process is using up a high amount of memory. That should help us track it down better.
Is there a way to paste the sreen shot of the task manager in here.
idk if vista has it, but in win7 i know there is a snipping tool, then upload it to imageshack.us and there will be a forum url link, then post it, or i think there's a little thing you can click and paste it in there and it puts in the coding.
Take a screen capture and put it in paint and make it a jpg file and then attach it to your post or host it on file sharing site like photobucket or imageshack.
