I will be building with i5 processor(quad-core) and 4GB RAM with the ability to increase later so I assume from what you've said that its best for me to get 64 bit. Is that correct?
lol 4MB RAM! Now I'm showing my ageCorrected your memory sizing typo.
Yes, go with 64-Bit.
Oh wow 4 MB of RAM xD And I though that my 512 MB of RAM is small,but 4 MB....omg lol...that's not enough even for MS-DOS xD
By the way be aware that ALL 32-bit programs you were using will not work on 64-bit OS so be sure that you do have those programs for 64-bit OS too otherwise if you buy 64-bit OS and THEN realize that,you are fuc!ed up hehehe.But there are many 64-bit programs now available so hopefully you won't have any problems.
Uh Oh I never considered that.By the way be aware that ALL 32-bit programs you were using will not work on 64-bit OS so be sure that you do have those programs for 64-bit OS too otherwise if you buy 64-bit OS and THEN realize that,you are fuc!ed up hehehe.But there are many 64-bit programs now available so hopefully you won't have any problems.
I currently run XP SP3, how do I find out if its 32 or 64?
And if it is 32 how do I also find out what programs it is going to affect if I go to 64 bit on the new system?
ok. Does any of this mean I must get 64bit GPU or HDD etc or is that totally not related?
Ignore his post. He was incorrect.
No you are wrong.Not all programs support 32-bit and 64-bit structure...
Some programs support only 32-bit,some support only 64-bit and some support both.So he should be sure that all his important programs also support 64-bit structure.Because if they don't,THEY WILL NOT WORK.
Yes it's true that most hardware supports 64-bit structure,but that does NOT apply for all programs.
As a computer programmer I know what I am saying and I have been dealing with this many times.
You said "ALL" programs. You can still install some 32-bit software on 64-bit, it would just not perform as well. But yes, some older games and programs will not work on 64-bit. I was worried about it when I made the switch from XP to 7, but I have never encountered the problem yet.
But from a novice standpoint, when you say all programs, one might think, say, any game they had before would not work, which would be false.
ok. Does any of this mean I must get 64bit GPU or other components or is that totally not related?
Programs written in 16bits definately not working in 64 bits OS, make sure You don't have any of these program you need to use. or you can buy the ultimate version and install win xp box in it.
By the way Microsoft office 2007 onenote printer is not working in the 64bit by default, you have to get third party utility to make it work.
cheers.
just to clarify with this a bit more, the 64-bit or 384 bit or whatever hat you see with gpus from what i know only has to do with the ram for it, so that number doesnt really matter, the faster the number the faster the gpu
