Krazyshank
Heres a copy of the ad:
This is a custom built ATX Mid-tower computer with Crisp black case, LEDs, side windows, and front vents.
Features/Specs:
- Windows 7 ULTIMATE x64
- 1000w KINGWIN Certified Power supply with BLUE LEDs and 120mm fan - 229$ NEW - http://www.newegg.com/Product/Product.aspx?Item=N82E16817121037
- Core 2 Quad 2.40 GHZ Q6600 (Fully overclockable VIA BIOS) 4 Cores - 398$ NEW - http://www.amazon.com/Intel-Q6600-Quad-Core-Processor-Cache/dp/B000LRMR26/ref=pd_cp_e_3
- XFX AMD Radeon HD 6850 Overclocked to 950mhz stable - 200$ NEW - http://xfxforce.com/en-us/products/graphiccards/hd 6000series/6850.aspx
- XFX 680i Full SLI Compatible - 160$ - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2959594&CatId=2541
- 4 GIGs of Gaming Grade Patriot ram 800mhz - 200$ NEW - http://patriotmemory.com/products/detailp.jsp?prodline=5&catid=33&prodgroupid=205&id=780&type=1
- DUAL Ethernet ports perfect for LAN parties
- Ultra Black Aluminus ATX Mid-Tower Case - 80$ NEW - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2486991&CatId=1858
- DVD/CD RW Bay
THAT IS 1267$ Total without the drive bay or OS!
Warranties:
- The Motherboard and Graphics card are covered by a FULL replacement warranty by XFX.
- I will help you fix any software issues free of charge, any time.
And how much would it go for if I added IN a 22" 1650x1050 monitor with it.
LINK: http://www.samsung.com/ph/consumer/.../LS22PEJSFV/XST/index.idx?pagetype=prd_detail
I have the ad for just the computer up for 700$. Is that a fair price? And how can I title my ad or do anything to get people attracted to it?
Features/Specs:
- DVD/CD RW Bay
Warranties:
