Hey guys/gals,
I am trying to practice/learn to overclock my PC (details in signiture).
Basically i made it all the way from 2.4GHz to 3.4GHZ, in which i can't get 3.4GHZ to stabilize. My settings in the BIOS is set at:
Muliplier = 9x
Bus Speed = 377
Voltage = Auto (found that if i set my voltage, stuff goes array. System won't boot, then turn up the voltage and windows crashes) Auto sets it at 1.256V (CPUZ)
Memory i am trying to figure out how to set it. So far CPUZ says that it is at 376MHz. Can't find where in my BIOS to double check this. Right now everything for memory is on AUTO. I am running Kingston ValueRAM 8GB totall (4x2GB) DDR2 800MHz. I don't really want to touch memory, because it's just a cheap kind.
So up till now, i have been setting-> booting up -> open CPUZ, REALTEMP, PRIME95 -> running PRIME95 for at least 4 hours. Everything has passed up until now.
Previous clock was 3.2GHz - 9x 356 (closest i could get). Voltage @ 1.232V (on AUTO). Memory at 376MHz (according to CPUZ). Temps never reached 49C under load 6 hours (Prime95).
I'm lost today, and can't figure out this one. Please, if you can help that would be awesome!
Muliplier = 9x
Bus Speed = 377
