Windows XP too slow
josephe
Hello everybody!
I have a big problem with my desktop pc.The computer where running fine until a couple of days ago I have turned the system on and the boot time was very long(about 3min or more). When I get finally in to the Windows is running on 28% load and is very slow.When is loaded in all the applications a few minutes is running fine suddenly jumps up on 25-30% load and is slowing the PC down so much that I have to wait to open Mozilla about 3 min.So I was fed up with this and I have reinstalled the OS.Now I have only the printer software, mozilla , nero ,winrar and acrobat reader installed on my pc but I still have the same issues.
When I have assembled my pc I have extracted a 2GB movie around 1 min.Now it takes more than 8 min because the counter stops and something is slowing the whole pc down :confused::confused::mad::mad: So at this stage I have no idea what to do...
My comp consist of: MSI P7N SLI Platinum - mobo
Intel Core 2 Quad Q6600 - 2.4Ghz
2 x 1GB Corsair Dominator DDR2 1066 Mhz
MSI 8800 Ultra 768 MB DDR3
250 GB WD 7200 rpm HDD
OS Windows XP Professional SP3 (genuine)
So you reinstalled your entire OS.Did you first delete ALL the partitions before installing or did you install it over the old one?Because if you did it over the old one,it's a good chance that something malicious is still on your HDD.
If you did it properly,try this:
-In the device manager under the IDE ATA/ATAPI CONTROLLERS check ALL the devices there and be sure that the transfer mode for all is DMA and not PIO...
-Do you hear any weird sounds from your HDD?No matter what,go to BIOS and turn on the option called HDD S.M.A.R.T. CAPABILITY and then save BIOS changes.On the next boot it will tell you wether your HDD is dying or not...
-Are your RAM chips old or damaged?To check that use free programs such as MemTest...
-What is the temperature of your processor (CPU) ?It should not be above 60 because if it's above 60,CPU is very very hot and that will affect the computer's performance a LOT.Optimal temperatures are from 30 to 40.Mine is 35.So if the temperatures are high,replace the thermal paste...
-Did you maybe by any chance overclocked the CPU in the BIOS?If yes,return all the changed settings to their default values or simply LOAD OPTIMAL DEFAULTS and save BIOS changes to CMOS...
-Are the fans/ventilators spin fast and properly in the right direction on the CPU cooler and graphic card (if any) ?
-Is your HDD very hot?HDDs are usually warm while they are being used,but it should not be VERY VERY hot...
-Did you change any hardware components recently?
-How big is the system temperature?It should not be bigger than 30 - 40.Mine is 25 - 28 all the time.
-How exactly did you format the HDD before installing Windows?You might try to convert all it's sectors to all zeros using KILL DISK before installing Windows OS...
Let us know the results of the above questions.
Cheers!
Hi!
Thank You for your post and sorry for the late relpy.I try to answer step by step on all your questions.
1.My HDD is separated on 3 partitions.The C: is where the OS is installed.I have formatted the HDD in command prompt with the installation disc and then I have installed the new OS on drive C: (no partitions deleted)
2.I did check the device manager and the transfer mode is DMA everywhere
3.I have enabled the HDD S.M.A.R.T function but is not coming up with any error.
4. 0 errors found after testing the memory modules
5.The CPU temp is 33C and it was overclocked to 3Ghz but I have reseted all the values on stock settings.
6.The system temp is 32C all the fans are running 3 x 80mm zalman fan is blowing cold air into the case and one 120mm zalman fan and a PCI slot fan is blowing the warm air out from the case.The( CPU cooler is Zalman CPS9500 ups)
7.The HDD is not warm at all
8.No hardware changes made recently.
After checking all this I still have the same issues....:(
I suggest you to start scanning your system for malware. Please do this in order posted.
1.
Please download and run TDSSkiller
When the program opens, click on the start scan button.
TDSSKiller will now scan your computer for the TDSS infection. When the scan has finished it will display a result screen stating whether or not the infection was found on your computer. If it was found it will display a screen similar to the one below.
To remove the infection simply click on the Continue button and TDSSKiller will attempt to clean the infection.
When it has finished cleaning the infection you will see a report stating whether or not it was successful as shown below.
If the log says will be cured after reboot, please reboot the system by pressing the reboot now button.
After running there will be a log that will be located at the root of your c:\ drive labeled tdsskiller with a series of numbers after it. Please open the log and copy and paste it back here.
2.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Post the logfile that HijackThis produces along with the Malwarebytes Anti-Malware log.
1. Downloaded and installed TDSSkiller - result:0 infections found
19:04:21.0812 3996 TDSS rootkit removing tool 2.6.10.0 Oct 17 2011 15:43:23
19:04:22.0015 3996 ============================================================
19:04:22.0015 3996 Current date / time: 2011/10/17 19:04:22.0015
19:04:22.0015 3996 SystemInfo:
19:04:22.0015 3996
19:04:22.0015 3996 OS Version: 5.1.2600 ServicePack: 3.0
19:04:22.0015 3996 Product type: Workstation
19:04:22.0015 3996 ComputerName: JOSEPHE
19:04:22.0015 3996 UserName: Jozef Dancok
19:04:22.0015 3996 Windows directory: C:\WINDOWS
19:04:22.0015 3996 System windows directory: C:\WINDOWS
19:04:22.0015 3996 Processor architecture: Intel x86
19:04:22.0015 3996 Number of processors: 4
19:04:22.0015 3996 Page size: 0x1000
19:04:22.0015 3996 Boot type: Normal boot
19:04:23.0859 3996 Initialize success
19:04:31.0609 1016 ============================================================
19:04:31.0609 1016 Scan started
19:04:31.0609 1016 Mode: Manual;
19:04:32.0593 1016 Abiosdsk - ok
19:04:32.0828 1016 abp480n5 - ok
19:04:33.0015 1016 ACPI (8fd99680a539792a30e97944fdaecf17) C:\WINDOWS\system32\DRIVERS\ACPI.sys
19:04:33.0046 1016 ACPI - ok
19:04:33.0218 1016 ACPIEC (9859c0f6936e723e4892d7141b1327d5) C:\WINDOWS\system32\drivers\ACPIEC.sys
19:04:33.0218 1016 ACPIEC - ok
19:04:33.0343 1016 adpu160m - ok
19:04:33.0515 1016 aec (8bed39e3c35d6a489438b8141717a557) C:\WINDOWS\system32\drivers\aec.sys
19:04:33.0546 1016 aec - ok
19:04:33.0781 1016 AegisP (2f7f3e8da380325866e566f5d5ec23d5) C:\WINDOWS\system32\DRIVERS\AegisP.sys
19:04:33.0781 1016 AegisP - ok
19:04:33.0968 1016 AFD (1e44bc1e83d8fd2305f8d452db109cf9) C:\WINDOWS\System32\drivers\afd.sys
19:04:33.0968 1016 AFD - ok
19:04:34.0093 1016 Aha154x - ok
19:04:34.0234 1016 aic78u2 - ok
19:04:34.0359 1016 aic78xx - ok
19:04:34.0500 1016 AliIde - ok
19:04:35.0093 1016 Ambfilt (267fc636801edc5ab28e14036349e3be) C:\WINDOWS\system32\drivers\Ambfilt.sys
19:04:35.0468 1016 Ambfilt - ok
19:04:35.0593 1016 amsint - ok
19:04:35.0859 1016 Arp1394 (b5b8a80875c1dededa8b02765642c32f) C:\WINDOWS\system32\DRIVERS\arp1394.sys
19:04:35.0875 1016 Arp1394 - ok
19:04:36.0000 1016 asc - ok
19:04:36.0125 1016 asc3350p - ok
19:04:36.0265 1016 asc3550 - ok
19:04:36.0453 1016 AsyncMac (b153affac761e7f5fcfa822b9c4e97bc) C:\WINDOWS\system32\DRIVERS\asyncmac.sys
19:04:36.0484 1016 AsyncMac - ok
19:04:36.0781 1016 atapi (9f3a2f5aa6875c72bf062c712cfa2674) C:\WINDOWS\system32\DRIVERS\atapi.sys
19:04:36.0781 1016 atapi - ok
19:04:36.0937 1016 Atdisk - ok
19:04:37.0093 1016 Atmarpc (9916c1225104ba14794209cfa8012159) C:\WINDOWS\system32\DRIVERS\atmarpc.sys
19:04:37.0109 1016 Atmarpc - ok
19:04:37.0265 1016 audstub (d9f724aa26c010a217c97606b160ed68) C:\WINDOWS\system32\DRIVERS\audstub.sys
19:04:37.0265 1016 audstub - ok
19:04:37.0546 1016 avc3 (c6cf76384dfc739b0be55abb79ad4dc0) C:\WINDOWS\system32\drivers\avc3.sys
19:04:37.0765 1016 avc3 - ok
19:04:38.0140 1016 avckf (b758a219e95c085405b1e356a8267610) C:\WINDOWS\system32\drivers\avckf.sys
19:04:38.0343 1016 avckf - ok
19:04:38.0531 1016 BDFM (54dbdd2ddb11776f1ebb85ccaba718bf) C:\WINDOWS\system32\DRIVERS\bdfm.sys
19:04:38.0531 1016 BDFM - ok
19:04:38.0828 1016 bdfsfltr (4c44d82e372a87b3cb439a7f14cfef03) C:\WINDOWS\system32\DRIVERS\bdfsfltr.sys
19:04:38.0890 1016 bdfsfltr - ok
19:04:39.0000 1016 Bdftdif (c23a8547d5ea6d0c3589961bfb7ff6d3) C:\Program Files\Common Files\BitDefender\BitDefender Firewall\bdftdif.sys
19:04:39.0000 1016 Bdftdif - ok
19:04:39.0140 1016 BdRawPr (d077f523538c9fb83b3c3fae13861579) C:\WINDOWS\system32\DRIVERS\bdrawpr.sys
19:04:39.0140 1016 BdRawPr - ok
19:04:39.0218 1016 bdselfpr (b6c3cb5978d91eabf405709fb0f0dbe9) C:\Program Files\BitDefender\BitDefender 2011\bdselfpr.sys
19:04:39.0218 1016 bdselfpr - ok
19:04:39.0375 1016 Beep (da1f27d85e0d1525f6621372e7b685e9) C:\WINDOWS\system32\drivers\Beep.sys
19:04:39.0375 1016 Beep - ok
19:04:39.0531 1016 cbidf2k (90a673fc8e12a79afbed2576f6a7aaf9) C:\WINDOWS\system32\drivers\cbidf2k.sys
19:04:39.0531 1016 cbidf2k - ok
19:04:39.0750 1016 cd20xrnt - ok
19:04:39.0906 1016 Cdaudio (c1b486a7658353d33a10cc15211a873b) C:\WINDOWS\system32\drivers\Cdaudio.sys
19:04:39.0921 1016 Cdaudio - ok
19:04:40.0078 1016 Cdfs (c885b02847f5d2fd45a24e219ed93b32) C:\WINDOWS\system32\drivers\Cdfs.sys
19:04:40.0093 1016 Cdfs - ok
19:04:40.0250 1016 Cdrom (1f4260cc5b42272d71f79e570a27a4fe) C:\WINDOWS\system32\DRIVERS\cdrom.sys
19:04:40.0265 1016 Cdrom - ok
19:04:40.0390 1016 Changer - ok
19:04:40.0531 1016 CmdIde - ok
19:04:40.0750 1016 Cpqarray - ok
19:04:40.0875 1016 dac2w2k - ok
19:04:41.0000 1016 dac960nt - ok
19:04:41.0156 1016 Disk (044452051f3e02e7963599fc8f4f3e25) C:\WINDOWS\system32\DRIVERS\disk.sys
19:04:41.0171 1016 Disk - ok
19:04:41.0484 1016 dmboot (d992fe1274bde0f84ad826acae022a41) C:\WINDOWS\system32\drivers\dmboot.sys
19:04:41.0656 1016 dmboot - ok
19:04:41.0906 1016 dmio (7c824cf7bbde77d95c08005717a95f6f) C:\WINDOWS\system32\drivers\dmio.sys
19:04:41.0937 1016 dmio - ok
19:04:42.0078 1016 dmload (e9317282a63ca4d188c0df5e09c6ac5f) C:\WINDOWS\system32\drivers\dmload.sys
19:04:42.0078 1016 dmload - ok
19:04:42.0234 1016 DMusic (8a208dfcf89792a484e76c40e5f50b45) C:\WINDOWS\system32\drivers\DMusic.sys
19:04:42.0234 1016 DMusic - ok
19:04:42.0375 1016 dpti2o - ok
19:04:42.0500 1016 drmkaud (8f5fcff8e8848afac920905fbd9d33c8) C:\WINDOWS\system32\drivers\drmkaud.sys
19:04:42.0515 1016 drmkaud - ok
19:04:42.0781 1016 Fastfat (38d332a6d56af32635675f132548343e) C:\WINDOWS\system32\drivers\Fastfat.sys
19:04:42.0812 1016 Fastfat - ok
19:04:42.0953 1016 Fdc (92cdd60b6730b9f50f6a1a0c1f8cdc81) C:\WINDOWS\system32\drivers\Fdc.sys
19:04:42.0953 1016 Fdc - ok
19:04:43.0109 1016 Fips (d45926117eb9fa946a6af572fbe1caa3) C:\WINDOWS\system32\drivers\Fips.sys
19:04:43.0171 1016 Fips - ok
19:04:43.0312 1016 Flpydisk (9d27e7b80bfcdf1cdd9b555862d5e7f0) C:\WINDOWS\system32\drivers\Flpydisk.sys
19:04:43.0312 1016 Flpydisk - ok
19:04:43.0484 1016 FltMgr (b2cf4b0786f8212cb92ed2b50c6db6b0) C:\WINDOWS\system32\drivers\fltmgr.sys
19:04:43.0515 1016 FltMgr - ok
19:04:43.0750 1016 Fs_Rec (3e1e2bd4f39b0e2b7dc4f4d2bcc2779a) C:\WINDOWS\system32\drivers\Fs_Rec.sys
19:04:43.0750 1016 Fs_Rec - ok
19:04:43.0906 1016 Ftdisk (6ac26732762483366c3969c9e4d2259d) C:\WINDOWS\system32\DRIVERS\ftdisk.sys
19:04:43.0937 1016 Ftdisk - ok
19:04:44.0093 1016 Gpc (0a02c63c8b144bd8c86b103dee7c86a2) C:\WINDOWS\system32\DRIVERS\msgpc.sys
19:04:44.0109 1016 Gpc - ok
19:04:44.0281 1016 HDAudBus (573c7d0a32852b48f3058cfd8026f511) C:\WINDOWS\system32\DRIVERS\HDAudBus.sys
19:04:44.0281 1016 HDAudBus - ok
19:04:44.0421 1016 hpn - ok
19:04:44.0625 1016 HTTP (f80a415ef82cd06ffaf0d971528ead38) C:\WINDOWS\system32\Drivers\HTTP.sys
19:04:44.0640 1016 HTTP - ok
19:04:44.0859 1016 i2omgmt - ok
19:04:44.0984 1016 i2omp - ok
19:04:45.0140 1016 i8042prt (4a0b06aa8943c1e332520f7440c0aa30) C:\WINDOWS\system32\DRIVERS\i8042prt.sys
19:04:45.0156 1016 i8042prt - ok
19:04:45.0296 1016 Imapi (083a052659f5310dd8b6a6cb05edcf8e) C:\WINDOWS\system32\DRIVERS\imapi.sys
19:04:45.0312 1016 Imapi - ok
19:04:45.0437 1016 ini910u - ok
19:04:47.0093 1016 IntcAzAudAddService (09e73e7455e7eac14e25739b30e16b52) C:\WINDOWS\system32\drivers\RtkHDAud.sys
19:04:47.0125 1016 IntcAzAudAddService - ok
19:04:47.0281 1016 IntelIde - ok
19:04:47.0421 1016 intelppm (8c953733d8f36eb2133f5bb58808b66b) C:\WINDOWS\system32\DRIVERS\intelppm.sys
19:04:47.0437 1016 intelppm - ok
19:04:47.0578 1016 Ip6Fw (3bb22519a194418d5fec05d800a19ad0) C:\WINDOWS\system32\drivers\ip6fw.sys
19:04:47.0578 1016 Ip6Fw - ok
19:04:47.0734 1016 IpFilterDriver (731f22ba402ee4b62748adaf6363c182) C:\WINDOWS\system32\DRIVERS\ipfltdrv.sys
19:04:47.0750 1016 IpFilterDriver - ok
19:04:47.0890 1016 IpInIp (b87ab476dcf76e72010632b5550955f5) C:\WINDOWS\system32\DRIVERS\ipinip.sys
19:04:47.0890 1016 IpInIp - ok
19:04:48.0062 1016 IpNat (cc748ea12c6effde940ee98098bf96bb) C:\WINDOWS\system32\DRIVERS\ipnat.sys
19:04:48.0093 1016 IpNat - ok
19:04:48.0250 1016 IPSec (23c74d75e36e7158768dd63d92789a91) C:\WINDOWS\system32\DRIVERS\ipsec.sys
19:04:48.0265 1016 IPSec - ok
19:04:48.0406 1016 IRENUM (c93c9ff7b04d772627a3646d89f7bf89) C:\WINDOWS\system32\DRIVERS\irenum.sys
19:04:48.0406 1016 IRENUM - ok
19:04:48.0546 1016 isapnp (05a299ec56e52649b1cf2fc52d20f2d7) C:\WINDOWS\system32\DRIVERS\isapnp.sys
19:04:48.0562 1016 isapnp - ok
19:04:48.0703 1016 Kbdclass (463c1ec80cd17420a542b7f36a36f128) C:\WINDOWS\system32\DRIVERS\kbdclass.sys
19:04:48.0718 1016 Kbdclass - ok
19:04:48.0890 1016 kmixer (692bcf44383d056aed41b045a323d378) C:\WINDOWS\system32\drivers\kmixer.sys
19:04:48.0921 1016 kmixer - ok
19:04:49.0078 1016 KSecDD (b467646c54cc746128904e1654c750c1) C:\WINDOWS\system32\drivers\KSecDD.sys
19:04:49.0093 1016 KSecDD - ok
19:04:49.0218 1016 lbrtfdc - ok
19:04:49.0375 1016 mnmdd (4ae068242760a1fb6e1a44bf4e16afa6) C:\WINDOWS\system32\drivers\mnmdd.sys
19:04:49.0375 1016 mnmdd - ok
19:04:49.0531 1016 Modem (dfcbad3cec1c5f964962ae10e0bcc8e1) C:\WINDOWS\system32\drivers\Modem.sys
19:04:49.0531 1016 Modem - ok
19:04:49.0984 1016 Monfilt (c7d9f9717916b34c1b00dd4834af485c) C:\WINDOWS\system32\drivers\Monfilt.sys
19:04:50.0296 1016 Monfilt - ok
19:04:50.0437 1016 Mouclass (35c9e97194c8cfb8430125f8dbc34d04) C:\WINDOWS\system32\DRIVERS\mouclass.sys
19:04:50.0437 1016 Mouclass - ok
19:04:50.0578 1016 MountMgr (a80b9a0bad1b73637dbcbba7df72d3fd) C:\WINDOWS\system32\drivers\MountMgr.sys
19:04:50.0593 1016 MountMgr - ok
19:04:50.0718 1016 mraid35x - ok
19:04:50.0875 1016 MRxDAV (11d42bb6206f33fbb3ba0288d3ef81bd) C:\WINDOWS\system32\DRIVERS\mrxdav.sys
19:04:50.0921 1016 MRxDAV - ok
19:04:51.0171 1016 MRxSmb (7d304a5eb4344ebeeab53a2fe3ffb9f0) C:\WINDOWS\system32\DRIVERS\mrxsmb.sys
19:04:51.0234 1016 MRxSmb - ok
19:04:51.0375 1016 Msfs (c941ea2454ba8350021d774daf0f1027) C:\WINDOWS\system32\drivers\Msfs.sys
19:04:51.0375 1016 Msfs - ok
19:04:51.0515 1016 MSKSSRV (d1575e71568f4d9e14ca56b7b0453bf1) C:\WINDOWS\system32\drivers\MSKSSRV.sys
19:04:51.0531 1016 MSKSSRV - ok
19:04:51.0671 1016 MSPCLOCK (325bb26842fc7ccc1fcce2c457317f3e) C:\WINDOWS\system32\drivers\MSPCLOCK.sys
19:04:51.0671 1016 MSPCLOCK - ok
19:04:51.0812 1016 MSPQM (bad59648ba099da4a17680b39730cb3d) C:\WINDOWS\system32\drivers\MSPQM.sys
19:04:51.0812 1016 MSPQM - ok
19:04:51.0968 1016 mssmbios (af5f4f3f14a8ea2c26de30f7a1e17136) C:\WINDOWS\system32\DRIVERS\mssmbios.sys
19:04:51.0968 1016 mssmbios - ok
19:04:52.0156 1016 Mup (de6a75f5c270e756c5508d94b6cf68f5) C:\WINDOWS\system32\drivers\Mup.sys
19:04:52.0156 1016 Mup - ok
19:04:52.0343 1016 NDIS (1df7f42665c94b825322fae71721130d) C:\WINDOWS\system32\drivers\NDIS.sys
19:04:52.0390 1016 NDIS - ok
19:04:52.0531 1016 NdisTapi (0109c4f3850dfbab279542515386ae22) C:\WINDOWS\system32\DRIVERS\ndistapi.sys
19:04:52.0546 1016 NdisTapi - ok
19:04:52.0687 1016 Ndisuio (f927a4434c5028758a842943ef1a3849) C:\WINDOWS\system32\DRIVERS\ndisuio.sys
19:04:52.0687 1016 Ndisuio - ok
19:04:52.0828 1016 NdisWan (edc1531a49c80614b2cfda43ca8659ab) C:\WINDOWS\system32\DRIVERS\ndiswan.sys
19:04:52.0859 1016 NdisWan - ok
19:04:53.0015 1016 NDProxy (9282bd12dfb069d3889eb3fcc1000a9b) C:\WINDOWS\system32\drivers\NDProxy.sys
19:04:53.0015 1016 NDProxy - ok
19:04:53.0156 1016 NetBIOS (5d81cf9a2f1a3a756b66cf684911cdf0) C:\WINDOWS\system32\DRIVERS\netbios.sys
19:04:53.0171 1016 NetBIOS - ok
19:04:53.0343 1016 NetBT (74b2b2f5bea5e9a3dc021d685551bd3d) C:\WINDOWS\system32\DRIVERS\netbt.sys
19:04:53.0375 1016 NetBT - ok
19:04:53.0546 1016 NIC1394 (e9e47cfb2d461fa0fc75b7a74c6383ea) C:\WINDOWS\system32\DRIVERS\nic1394.sys
19:04:53.0546 1016 NIC1394 - ok
19:04:53.0765 1016 Npfs (3182d64ae053d6fb034f44b6def8034a) C:\WINDOWS\system32\drivers\Npfs.sys
19:04:53.0781 1016 Npfs - ok
19:04:54.0031 1016 Ntfs (78a08dd6a8d65e697c18e1db01c5cdca) C:\WINDOWS\system32\drivers\Ntfs.sys
19:04:54.0046 1016 Ntfs - ok
19:04:54.0234 1016 Null (73c1e1f395918bc2c6dd67af7591a3ad) C:\WINDOWS\system32\drivers\Null.sys
19:04:54.0234 1016 Null - ok
19:04:57.0375 1016 nv (6733e80a193fc36f41c24142b0c45c0e) C:\WINDOWS\system32\DRIVERS\nv4_mini.sys
19:05:00.0171 1016 nv - ok
19:05:00.0375 1016 NwlnkFlt (b305f3fad35083837ef46a0bbce2fc57) C:\WINDOWS\system32\DRIVERS\nwlnkflt.sys
19:05:00.0375 1016 NwlnkFlt - ok
19:05:00.0515 1016 NwlnkFwd (c99b3415198d1aab7227f2c88fd664b9) C:\WINDOWS\system32\DRIVERS\nwlnkfwd.sys
19:05:00.0531 1016 NwlnkFwd - ok
19:05:00.0687 1016 ohci1394 (ca33832df41afb202ee7aeb05145922f) C:\WINDOWS\system32\DRIVERS\ohci1394.sys
19:05:00.0687 1016 ohci1394 - ok
19:05:00.0843 1016 Parport (5575faf8f97ce5e713d108c2a58d7c7c) C:\WINDOWS\system32\drivers\Parport.sys
19:05:00.0875 1016 Parport - ok
19:05:01.0000 1016 PartMgr (beb3ba25197665d82ec7065b724171c6) C:\WINDOWS\system32\drivers\PartMgr.sys
19:05:01.0015 1016 PartMgr - ok
19:05:01.0156 1016 ParVdm (70e98b3fd8e963a6a46a2e6247e0bea1) C:\WINDOWS\system32\drivers\ParVdm.sys
19:05:01.0171 1016 ParVdm - ok
19:05:01.0312 1016 PCI (a219903ccf74233761d92bef471a07b1) C:\WINDOWS\system32\DRIVERS\pci.sys
19:05:01.0328 1016 PCI - ok
19:05:01.0453 1016 PCIDump - ok
19:05:01.0593 1016 PCIIde (ccf5f451bb1a5a2a522a76e670000ff0) C:\WINDOWS\system32\DRIVERS\pciide.sys
19:05:01.0593 1016 PCIIde - ok
19:05:01.0765 1016 Pcmcia (9e89ef60e9ee05e3f2eef2da7397f1c1) C:\WINDOWS\system32\drivers\Pcmcia.sys
19:05:01.0796 1016 Pcmcia - ok
19:05:01.0921 1016 PDCOMP - ok
19:05:02.0046 1016 PDFRAME - ok
19:05:02.0171 1016 PDRELI - ok
19:05:02.0296 1016 PDRFRAME - ok
19:05:02.0437 1016 perc2 - ok
19:05:02.0562 1016 perc2hib - ok
19:05:02.0718 1016 PptpMiniport (efeec01b1d3cf84f16ddd24d9d9d8f99) C:\WINDOWS\system32\DRIVERS\raspptp.sys
19:05:02.0718 1016 PptpMiniport - ok
19:05:02.0875 1016 PSched (09298ec810b07e5d582cb3a3f9255424) C:\WINDOWS\system32\DRIVERS\psched.sys
19:05:02.0890 1016 PSched - ok
19:05:03.0031 1016 Ptilink (80d317bd1c3dbc5d4fe7b1678c60cadd) C:\WINDOWS\system32\DRIVERS\ptilink.sys
19:05:03.0031 1016 Ptilink - ok
19:05:03.0156 1016 ql1080 - ok
19:05:03.0296 1016 Ql10wnt - ok
19:05:03.0437 1016 ql12160 - ok
19:05:03.0593 1016 ql1240 - ok
19:05:03.0718 1016 ql1280 - ok
19:05:03.0859 1016 RasAcd (fe0d99d6f31e4fad8159f690d68ded9c) C:\WINDOWS\system32\DRIVERS\rasacd.sys
19:05:03.0859 1016 RasAcd - ok
19:05:04.0000 1016 Rasl2tp (11b4a627bc9614b885c4969bfa5ff8a6) C:\WINDOWS\system32\DRIVERS\rasl2tp.sys
19:05:04.0015 1016 Rasl2tp - ok
19:05:04.0156 1016 RasPppoe (5bc962f2654137c9909c3d4603587dee) C:\WINDOWS\system32\DRIVERS\raspppoe.sys
19:05:04.0171 1016 RasPppoe - ok
19:05:04.0296 1016 Raspti (fdbb1d60066fcfbb7452fd8f9829b242) C:\WINDOWS\system32\DRIVERS\raspti.sys
19:05:04.0312 1016 Raspti - ok
19:05:04.0484 1016 Rdbss (7ad224ad1a1437fe28d89cf22b17780a) C:\WINDOWS\system32\DRIVERS\rdbss.sys
19:05:04.0531 1016 Rdbss - ok
19:05:04.0656 1016 RDPCDD (4912d5b403614ce99c28420f75353332) C:\WINDOWS\system32\DRIVERS\RDPCDD.sys
19:05:04.0671 1016 RDPCDD - ok
19:05:04.0843 1016 rdpdr (15cabd0f7c00c47c70124907916af3f1) C:\WINDOWS\system32\DRIVERS\rdpdr.sys
19:05:04.0875 1016 rdpdr - ok
19:05:05.0062 1016 RDPWD (fc105dd312ed64eb66bff111e8ec6eac) C:\WINDOWS\system32\drivers\RDPWD.sys
19:05:05.0062 1016 RDPWD - ok
19:05:05.0218 1016 redbook (f828dd7e1419b6653894a8f97a0094c5) C:\WINDOWS\system32\DRIVERS\redbook.sys
19:05:05.0234 1016 redbook - ok
19:05:05.0453 1016 RT73 (6ea04a4370609e5e1eaeee898a2ab6ac) C:\WINDOWS\system32\DRIVERS\rt73.sys
19:05:05.0500 1016 RT73 - ok
19:05:05.0656 1016 Secdrv (90a3935d05b494a5a39d37e71f09a677) C:\WINDOWS\system32\DRIVERS\secdrv.sys
19:05:05.0656 1016 Secdrv - ok
19:05:05.0812 1016 serenum (0f29512ccd6bead730039fb4bd2c85ce) C:\WINDOWS\system32\DRIVERS\serenum.sys
19:05:05.0812 1016 serenum - ok
19:05:05.0953 1016 Serial (cca207a8896d4c6a0c9ce29a4ae411a7) C:\WINDOWS\system32\DRIVERS\serial.sys
19:05:05.0968 1016 Serial - ok
19:05:06.0109 1016 Sfloppy (8e6b8c671615d126fdc553d1e2de5562) C:\WINDOWS\system32\drivers\Sfloppy.sys
19:05:06.0109 1016 Sfloppy - ok
19:05:06.0250 1016 Simbad - ok
19:05:06.0375 1016 Sparrow - ok
19:05:06.0515 1016 splitter (ab8b92451ecb048a4d1de7c3ffcb4a9f) C:\WINDOWS\system32\drivers\splitter.sys
19:05:06.0515 1016 splitter - ok
19:05:06.0671 1016 sr (76bb022c2fb6902fd5bdd4f78fc13a5d) C:\WINDOWS\system32\DRIVERS\sr.sys
19:05:06.0687 1016 sr - ok
19:05:06.0906 1016 Srv (47ddfc2f003f7f9f0592c6874962a2e7) C:\WINDOWS\system32\DRIVERS\srv.sys
19:05:06.0953 1016 Srv - ok
19:05:07.0093 1016 swenum (3941d127aef12e93addf6fe6ee027e0f) C:\WINDOWS\system32\DRIVERS\swenum.sys
19:05:07.0093 1016 swenum - ok
19:05:07.0234 1016 swmidi (8ce882bcc6cf8a62f2b2323d95cb3d01) C:\WINDOWS\system32\drivers\swmidi.sys
19:05:07.0250 1016 swmidi - ok
19:05:07.0375 1016 symc810 - ok
19:05:07.0515 1016 symc8xx - ok
19:05:07.0640 1016 sym_hi - ok
19:05:07.0859 1016 sym_u3 - ok
19:05:08.0000 1016 sysaudio (8b83f3ed0f1688b4958f77cd6d2bf290) C:\WINDOWS\system32\drivers\sysaudio.sys
19:05:08.0015 1016 sysaudio - ok
19:05:08.0250 1016 Tcpip (9aefa14bd6b182d61e3119fa5f436d3d) C:\WINDOWS\system32\DRIVERS\tcpip.sys
19:05:08.0312 1016 Tcpip - ok
19:05:08.0453 1016 TDPIPE (6471a66807f5e104e4885f5b67349397) C:\WINDOWS\system32\drivers\TDPIPE.sys
19:05:08.0453 1016 TDPIPE - ok
19:05:08.0609 1016 TDTCP (c56b6d0402371cf3700eb322ef3aaf61) C:\WINDOWS\system32\drivers\TDTCP.sys
19:05:08.0609 1016 TDTCP - ok
19:05:08.0843 1016 TermDD (88155247177638048422893737429d9e) C:\WINDOWS\system32\DRIVERS\termdd.sys
19:05:08.0843 1016 TermDD - ok
19:05:08.0984 1016 TosIde - ok
19:05:09.0203 1016 Trufos (29c497fc09c655b7bafcfafb6e76b8eb) C:\WINDOWS\system32\DRIVERS\Trufos.sys
19:05:09.0203 1016 Trufos - ok
19:05:09.0359 1016 Udfs (5787b80c2e3c5e2f56c2a233d91fa2c9) C:\WINDOWS\system32\drivers\Udfs.sys
19:05:09.0375 1016 Udfs - ok
19:05:09.0500 1016 ultra - ok
19:05:09.0718 1016 Update (402ddc88356b1bac0ee3dd1580c76a31) C:\WINDOWS\system32\DRIVERS\update.sys
19:05:09.0796 1016 Update - ok
19:05:09.0968 1016 usbccgp (173f317ce0db8e21322e71b7e60a27e8) C:\WINDOWS\system32\DRIVERS\usbccgp.sys
19:05:09.0984 1016 usbccgp - ok
19:05:10.0125 1016 usbehci (65dcf09d0e37d4c6b11b5b0b76d470a7) C:\WINDOWS\system32\DRIVERS\usbehci.sys
19:05:10.0125 1016 usbehci - ok
19:05:10.0281 1016 usbhub (1ab3cdde553b6e064d2e754efe20285c) C:\WINDOWS\system32\DRIVERS\usbhub.sys
19:05:10.0296 1016 usbhub - ok
19:05:10.0437 1016 usbohci (0daecce65366ea32b162f85f07c6753b) C:\WINDOWS\system32\DRIVERS\usbohci.sys
19:05:10.0437 1016 usbohci - ok
19:05:10.0593 1016 usbprint (a717c8721046828520c9edf31288fc00) C:\WINDOWS\system32\DRIVERS\usbprint.sys
19:05:10.0593 1016 usbprint - ok
19:05:10.0718 1016 usbscan (a0b8cf9deb1184fbdd20784a58fa75d4) C:\WINDOWS\system32\DRIVERS\usbscan.sys
19:05:10.0734 1016 usbscan - ok
19:05:10.0875 1016 USBSTOR (a32426d9b14a089eaa1d922e0c5801a9) C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS
19:05:10.0875 1016 USBSTOR - ok
19:05:11.0015 1016 VgaSave (0d3a8fafceacd8b7625cd549757a7df1) C:\WINDOWS\System32\drivers\vga.sys
19:05:11.0015 1016 VgaSave - ok
19:05:11.0140 1016 ViaIde - ok
19:05:11.0312 1016 VolSnap (4c8fcb5cc53aab716d810740fe59d025) C:\WINDOWS\system32\drivers\VolSnap.sys
19:05:11.0328 1016 VolSnap - ok
19:05:11.0468 1016 Wanarp (e20b95baedb550f32dd489265c1da1f6) C:\WINDOWS\system32\DRIVERS\wanarp.sys
19:05:11.0484 1016 Wanarp - ok
19:05:11.0609 1016 WDICA - ok
19:05:11.0765 1016 wdmaud (6768acf64b18196494413695f0c3a00f) C:\WINDOWS\system32\drivers\wdmaud.sys
19:05:11.0781 1016 wdmaud - ok
19:05:11.0828 1016 MBR (0x1B8) (8f558eb6672622401da993e1e865c861) \Device\Harddisk0\DR0
19:05:11.0968 1016 \Device\Harddisk0\DR0 - ok
19:05:11.0968 1016 Boot (0x1200) (bdb06e8a4836d48008894dd4b4a2ea79) \Device\Harddisk0\DR0\Partition0
19:05:11.0968 1016 \Device\Harddisk0\DR0\Partition0 - ok
19:05:11.0984 1016 Boot (0x1200) (c496f7acee39089110ca8c59a3d62fba) \Device\Harddisk0\DR0\Partition1
19:05:11.0984 1016 \Device\Harddisk0\DR0\Partition1 - ok
19:05:12.0000 1016 Boot (0x1200) (364da8e787969ca4cb08ed3a290c1baa) \Device\Harddisk0\DR0\Partition2
19:05:12.0000 1016 \Device\Harddisk0\DR0\Partition2 - ok
19:05:12.0000 1016 ============================================================
19:05:12.0000 1016 Scan finished
19:05:12.0000 1964 Detected object count: 0
19:05:12.0000 1964 Actual detected object count: 0
19:05:56.0906 3128 Deinitialize success
Malwarebytes' Anti-Malware 1.51.2.1300
www.malwarebytes.org
Database version: 7966
Windows 5.1.2600 Service Pack 3
Internet Explorer 8.0.6001.18702
10/17/2011 7:29:06 PM
mbam-log-2011-10-17 (19-29-06).txt
Scan type: Quick scan
Objects scanned: 170580
Time elapsed: 4 minute(s), 55 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Folders Infected:
Files Infected:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 7:39:43 PM, on 10/17/2011
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\BitDefender\BitDefender 2011\vsserv.exe
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\BitDefender\BitDefender 2011\updatesrv.exe
C:\Program Files\BitDefender\BitDefender 2011\bdagent.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\Common Files\Java\Java Update\jusched.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATICAE.EXE
C:\Program Files\Sitecom\Sitecom Wireless Network USB Adapter Turbo G WL-172\Installer\WLANUTL.EXE
C:\WINDOWS\system32\msiexec.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O2 - BHO: EpsonToolBandKicker Class - {E99421FB-68DD-40F0-B4AC-B7027CAE2F1A} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll
O3 - Toolbar: EPSON Web-To-Page - {EE5D279F-081B-4404-994D-C6B60AAEBA6D} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll
O3 - Toolbar: BitDefender Toolbar - {381FFDE8-2394-4F90-B10D-FC6124A40F8C} - C:\Program Files\BitDefender\BitDefender 2011\IEToolbar.dll
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [MSIAfterburner] "C:\Program Files\MSI Afterburner\MSIAfterburner.exe" /s
O4 - HKLM\..\Run: [BitDefender Antiphishing Helper] "C:\Program Files\BitDefender\BitDefender 2011\ieshow.exe"
O4 - HKLM\..\Run: [BDAgent] "C:\Program Files\BitDefender\BitDefender 2011\bdagent.exe"
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
O4 - HKCU\..\Run: [EPSON Stylus DX4400 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATICAE.EXE /FU "C:\WINDOWS\TEMP\E_SAA.tmp" /EF "HKCU"
O4 - Global Startup: Sitecom Wireless Utility.lnk = C:\Program Files\Sitecom\Sitecom Wireless Network USB Adapter Turbo G WL-172\Installer\WLANUTL.EXE
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: NVIDIA Update Service Daemon (nvUpdatusService) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe
O23 - Service: Soluto PCGenome Core Service (SolutoService) - Unknown owner - C:\Program Files\Soluto\SolutoService.exe (file missing)
O23 - Service: BitDefender Update Server v2 (Update Server) - BitDefender - C:\Program Files\Common Files\BitDefender\BitDefender Arrakis Server\bin\arrakis3.exe
O23 - Service: BitDefender Desktop Update Service (Updatesrv) - BitDefender S.R.L. - C:\Program Files\BitDefender\BitDefender 2011\updatesrv.exe
O23 - Service: BitDefender Virus Shield (VSSERV) - BitDefender S.R.L. - C:\Program Files\BitDefender\BitDefender 2011\vsserv.exe
End of file - 6011 bytes
The next step would be to download and run ccleaner.
http://download.cnet.com/ccleaner/
Download, install and then open the program, don't change any settings, click on run cleaner. This may take a few minutes to complete depending on the last time temp files were deleted. After running, reboot your system and see if there has been any improvement. If not, there are other issues, possibly a failing hard drive.
ccleaner scan done I have restarted my PC but the boot time is still very long... is running ok a while in the next minute is on 30% load.....:confused:
Open task manager and tell me what process is using most of the cpu/memory.
What brand of hard drive do you have? IDE or SATA?
Boot to Windows,once that is done close ALL opened programs including those which are running in the background,open the task manager,go to the PERFORMANCE tab and tell us how big is the CPU USAGE (on the left) when the system is idle for at least 10 minutes?
Because if it jumps too high very often (over 20% or even 40%) and you are not running anything then something in Windows OS is using your processor a lot.So do what johnb35 said and go to the PROCESSES tab and take a look at each process and the one which uses the most of the CPU is the cause.Try to terminate that process and see if it improved anything.
Report back with the results.
Cheers mates!
Hi!
My HDD is SATA.There is only the anti-virus updater is running on the background and the task manager both values are 01 under the CPU.The app is called vsserv.exe. But this is the only application and something is slowing it down that much that I cant even write a text into google search..
After the update finishes is running fine then suddenly from nothing jumps up on 27-30% and when I open the task manager is shows only on the task manager app is using 01 CPU.And the HDD LED is not flashing is constantly on....
[/url] bmp upload[/IMG]
So under the PROCESSES tab,there is not a single process which is using too much RAM (Mem Usage) or/and CPU?
Try putting a check mark at the check box at the bottom of the window which says "Show processes from all users".Then close and reopen the task manager and see if now you can see any process(es) which use too much RAM (Mem Usage) or/and CPU.
By the way...how XP works in Safe Mode?Is it also slow or better?
You can also try to boot Linux Ubuntu computer operating system from the CD-ROM disk and see how it works.If that ALSO works very slow then something is wrong with your hardware and NOT the software.
Try all that above and report back.
Cheers!
Under the processes tab the only applications witch are using the CPU and memory is the task manager, the anti virus updater, windows explorer sometimes jumps up to 01 on CPU.But all this is only 01 on CPU the max used memory is 24,368 K witch is not too much.So this is the reason why I dont get this....Nearly nothing is running on the system just the windows applications and the antivirus and the system is loaded on 27% but is looks like if is running on 100% load because for minutes everything is freezing on the screen.
I have tried under safe mode.It works perfectly.Very fast under 10 sec in the Windows..no issues under safe mode..:confused:
So Windows works okay in safe mode...that is a good news because now we know it is not the hardware issue.If Windows works so slow in normal mode after all you tryed,it can be that a specific amount of important Windows OS data is either corrupted or the HDD sectors on which it is located are messed up or even damaged.Because if they are,that WILL cause a LOT of problems.So here is what you should do:
-backup ALL your important data...
-now you will need to write zeros to EACH sector on your HDD by using special tools for that.I recommend a DOS tool called KILL DISK.
NOTE: When kill disk writes zeros to all HDD sectors,all your data on that HDD is gone forever so be sure you back up everything!
-When kill disk is finished,install Windows XP again.Just be sure to choose the NORMAL SLOW format and NOT the QUICK one!It is called "Format the partition using the NTFS file system".
-Finish the Windows OS installation and after that install ONLY your drivers and NOTHING else.Once you have done that,restart your computer for several times and if after all that computer works normal then the problem is solved.If computer works super slow again,then your HDD is probably dying.
Try this and report back.If you do not have XP installation disk,get it from someone because you need it.
Cheers!
Wow I just noticed this was my 1000. post ^^ Cool ^^ I gotta celebrate this ^^
Hello everybody!
Sorry for the late relpy but I had to order a 500GB external desktop HDD to backup all my data.So I have deleted all the partitions and created new (only two this time), formatted with NTFS file system, reinstalled the OS and the result is very good:D:D
I get the XP Welcome screen around 10 seconds and the PC is very fast.
I have to say Thank You to everybody who posted comments to this thread and gave me good advices.
Once again....Thanks!!!:good:
Sonia had Java packages on her machine that were slowing it way down. Also, I don't entirely trust MS. When an OS gets old, and they want you to BUY their new one, I wouldn't put it past them to slip something ugly into their "Updates". Out of curiosity, are you using Windopes "Automatic Update" ?
That is why I don't use updates :P ...at all :P
But if what you are saying is true then that kinda sucks what Microsoft is doing.They really should not be doing that.
Windows updates are worhless..........
Oh finally! :D
Believe it or not,you are the FIRST person here who actually agrees with me haha!Because 99% of people say that updating system all the time is good when actually is not since you are just risking it like hell all until you don't get a constant BSOD :D
They say that updates are good for the security and system stability lmao.I say:"If you want security,install,configure properly and update a good antivirus software.If you want system stability,don't keep updating system like nuts and rather learn how to use computers :D "
Just yeasterday I was fixing someone's laptop which had XP OS installed and I found more than 150 updates installed.I asked her:"Do you know what all this is for?" She said:"No." Then I asked her:"So why did you install SO many of these called UPDATES?" And she said:"Someone told me that my computer will work better with that."
And guess what!She said that after she installed all these updates,that she can now barely surf the internet and that everything works like crap hahaha!!! I wonder why is that happening to her lmao!
The problem is that people THINK that having all the newest is the BEST while that is not stricty true.What they need is KNOWLEDGE in order to know what is good and what not.Because all newest things are not always better or/and neccessary.Hell I NEVER EVER update my XP system and everything works prefect not to mention that I installed XP on my old PC in 2004. and they still work perfect.Also my computer hardware is almost 20 years old and it works better than the newest hardware to some people.Why? The answer is simple: THEY SIMPLY DO NOT KNOW HOW TO USE COMPUTERS AND EVEN THE STRONGEST HARDWARE AND ALL UPDATES WILL NOT HELP THEM AT ALL ;)
People usually laugh at me when I tell them how weak my configuration is,but I simply tell them:"Laugh if you want,but I am not the one who is having problems with every single software and who reinstalls Windows OS every few weeks."
Cheers!
