Hey,
Over the past couple of years I have been playing my games on a computer that used an onboard Nvidia geforce 8200 graphics card. The card is not really made for gaming but has done ok for a while and I haven’t minded low graphic settings. However, skyrim is literally just around the corner so I think it’s time to upgrade to the ATI 6850.
Only question now is which version of this card do I buy? I have never really understood the difference between sapphire, XFX, Asus, Gigabyte and any others which I may be unaware of. All I can see is the price, which implies to me that different versions perform on different levels.
So really my question is which of these companies would you recommend buying the 6850 from.
I have a budget of £150 (should be fine as I haven’t seen any over that price) however I have been told that I will need a new PSU. If you could also recommend one (based on the spec of my current pc including the new graphics card at the bottom) that would be much appreciated.
Thanks for any help.
Also when I buy it I will most likely go to amazon.co.uk but if there are any other good sites which will do it cheaper and will be reliable with shipping the part that would be great.
Current system (I did not build this)
Athlon II X4 2.9GHz
4gb ram
Nvidia geforce 8200 shared memory 1gb
Windows 7
Unsure of current psu sorry
Athlon II X4 2.9GHz
4gb ram
Windows 7
